JS Tech RGB Scart to Component - (to HDMI via amp?)
Old 20-05-2008, 8:32 PM   #1
spaceman763's Avatar
6,480, Level: 19
Points: 6,480, Level: 19 Points: 6,480, Level: 19 Points: 6,480, Level: 19
Thanks: Gave 126, Got 78
Hi guys
Apologies for the confusing title. I've recently bought a JS Tech converter for use with my Sky+ box and projector. S video just wasn't cutting it so I am now going to convert the rgb scart output on my sky box to component and plug this into my pj.
I also need to buy an amp but I think I read somewhere that if a plugged the component cables to an amp and upconverted via HDMI it would not work. Is this true of all amps?
Regards
Old 22-05-2008, 11:36 AM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: JS Tech RGB Scart to Component - (to HDMI via amp?)
some amp shave video upconversion and will convert COmposite/s-video and componment to digiotal and sent ove rHDMI some will even scale to 1080i 720p but i would run component direct to PJ for sky and HDMI for HD sources.
Old 23-05-2008, 9:22 AM   #3
Assured Advertiser
Joe Fernand's Avatar
36,543, Level: 46
Points: 36,543, Level: 46 Points: 36,543, Level: 46 Points: 36,543, Level: 46
Activity: 20.3%
Activity: 20.3% Activity: 20.3% Activity: 20.3%
Thanks: Gave 205, Got 1,344
Hello spaceman763
Horny must have been sniffing soldering flux when he was posting yesterday
There is no technical reason why a Converted to YUV (via a JS Tech RGB2YUV Converter) signal cant then be converted to Digital and possibly re-scaled via a suitable AV Receiver.
Though keep in mind two layers of conversion may result in an inferior signal vs. just one conversion.
Joe
