new HDMI cables
Thread Closed
Old 17-05-2008, 1:13 PM   #1
Mad Mr H's Avatar
20,266, Level: 34
Points: 20,266, Level: 34 Points: 20,266, Level: 34 Points: 20,266, Level: 34
Thanks: Gave 604, Got 335
new HDMI cables
I have now ordered my Silver Starlight Wireworld cables for my main Cinema room. For my TV room I ordered Van Damme HDMI cables.
I was originally going to order Chord and Wireworld.
I did take notice of those that claim the shorter cables make no difference and so changed from my original Chord to Van Damme - This represented a saving and for my TV room there is no real need for "Videophile" quality.
Why the Silver Starlight Wireworld? The main run is about 7 meters long, at this distance there are clear differences between the cheaper and more expensive ranges of cable.
I did actually also order matching Silver Starlight shorter cables - this will allow me to test side by side Van Damme, Wireworld, Cheap & FREE cables.
Free, Cheap and Van Damme are already here, Wireworld delivery on route .
Old 17-05-2008, 1:30 PM   #2
Apone's Avatar
6,813, Level: 19
Points: 6,813, Level: 19 Points: 6,813, Level: 19 Points: 6,813, Level: 19
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 212, Got 120
Re: new HDMI cables
Looing foward to your findings
Old 17-05-2008, 1:35 PM   #3
Conspicuous Member
recruit's Avatar
26,913, Level: 39
Points: 26,913, Level: 39 Points: 26,913, Level: 39 Points: 26,913, Level: 39
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
Thanks: Gave 521, Got 593
Re: new HDMI cables
I will be keeping an eye on this thread, what I will ask is to let Mad Mr H have his say and then comment on his finding's please
Mad Mr H (18-05-2008)
Old 18-05-2008, 10:18 AM   #4
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Well they won't just be my findings. I usually have a group of members here and we all look at what we actually see (or hear), we don't always agree, But we do respect each others opinions, If I find a better way for something I will always consider the change - Not every step is forward.
Wirewolrd cables are in transit to me .
I might consider getting some Chord cables in to compare after the initial tests are run, thats mainly for the longer run where I think most agree that every meter counts on an HDMI cable. (I will consider others that might be available from those present at the test and that will include ANY brand or price)
The long run (7-9m) will start as a single cable, There may be later tests using HDMI boosters that ALSO have a jitter reduction circuit, just a HDMI booster in my opinion is not the correct product.
Old 18-05-2008, 11:27 AM   #5
davepuma's Avatar
32,005, Level: 43
Points: 32,005, Level: 43 Points: 32,005, Level: 43 Points: 32,005, Level: 43
Activity: 34.1%
Activity: 34.1% Activity: 34.1% Activity: 34.1%
Thanks: Gave 396, Got 2,176
Re: new HDMI cables
Where have all the other replies gone? Hardly fair that?!
Old 18-05-2008, 11:40 AM   #6
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Points: 3,397, Level: 13 Points: 3,397, Level: 13 Points: 3,397, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 3, Got 100
Re: new HDMI cables
Let us send you our kit too... and we can compare???
UKHDMI is an Assured Advertiser.
Cablesson ¦ Octava
HDMI Cable - We won the award of the most active company at CEDIA 08.
Old 18-05-2008, 12:20 PM   #7
3,938, Level: 14
Points: 3,938, Level: 14 Points: 3,938, Level: 14 Points: 3,938, Level: 14
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 15, Got 133
Re: new HDMI cables
For the findings of a subjective test to be credible, the test procedures / protocols used are of fundamental importance. Could you briefly outline the procedures to be adopted for your HDMI cable tests?
Alan
Old 18-05-2008, 12:33 PM   #8
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Alan
Hi Alan,
In the past various side by side tests have been carried out in my cinema and 2ch audio system, These are all "Fun" days for those involved and the objective is always to prove the best of any equipment or cable within "MY" system. I accept that what is best for my system may not suit other systems.
Are there any tests you would like to see done ?
PLEASE NOTE there will be NO HDMI Audio tests run, this will be video only.
I have the following players here
HD DVD - XA1, XA1 with HD SDI modification, EP10, EP35, XE1
Blu Ray - Samsung BDP-S1000, Sony S1 with HD SDI modification, Panasonic BD10
There may also be a Denon 3800 Blu Ray player here
Old 18-05-2008, 12:59 PM   #9
6,996, Level: 19
Points: 6,996, Level: 19 Points: 6,996, Level: 19 Points: 6,996, Level: 19
Thanks: Gave 16, Got 84
Re: new HDMI cables
If possible screen shots of any differences would be appreciated, and would lend credability to any findings you make.
Cheers,
John.
Last edited by recruit; 18-05-2008 at 1:06 PM. Reason: Removed content as not asking for guidance on moderation matters.
Old 18-05-2008, 1:00 PM   #10
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
The system used for testing will be as follows (subject to change as I tend to change kit rather often!)
HD players as listed in post above.
Players will have either 0.5m or 1.0m HDMI/HDMI output cables.
HD sources will then pass through a 4:1 HDMI switcher box. This box also has a DVI output option fitted.
A 7m cable will then link the 4:1 switcher to the scaler.
The scaler a "TVONE C2-7200" then sends the images out to two projectors - This is a dual engine scaler with the ability to separately control the two projectors - In "NORMAL" use in my system this scalar does "edge blending" and "24Hz to 72Hz" refresh rate changes from HD sources.
From the scalar a 1m and 3m cable link the scalar to a HDMI/RGBHV with gamma control conversion unit.
Currently the Barco Cine9 projectors (2500x2000 resolution, 180+Mhz bandwidth) are running RGBHV, but an optional DVI input card should be installed very soon (in both)
People might pick up on the fact that the main link to the projectors differ in length 1m and 3m - This should actually be an advantage as the same brand can be tested 1 & 3m in direct comparison. It is also possible to run the same length of 3m with ease.
A more direct route of HD Source to PJ with DVI input is also possible.
Side by Side tests in this system are easy and at the press of a button. Actual changing cables takes the time.
Again I can try most things BUT will be more happy to test items that will be of use in "MY" system .
Old 18-05-2008, 1:10 PM   #11
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Originally Posted by JohnWH View Post
Hi Andy, And may I say what a terribly nice bloke you seem to be .
Cheers,
John.
Hi John,
Once "Quoted" your here to stay
Screen shots are possible - I have to say that when we tested a bunch of scalers here that screen shots did not really help. There was an obvious visual difference that we all saw, That did also include easy of use as well as visual quality.
The issue is that the screen most people view on their PC does not have the ability to represent the actual image. ALSO I have to say that screen shots in tests I have seen in the past have been manipulated to suit sellers etc.
I have no flag to fly here, I'm gonna enjoy the results, and use the best I find suited to my system. I am also open to the possibility that I see no difference at all and that maybe expensive cables are just jewelry for my cinema .
Andy H.
PS - Ironic that you miss spell "credability" , H runs and checks he has spelt his name right .
Old 18-05-2008, 2:16 PM   #12
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Re: new HDMI cables
Given the highly subjective nature of these sorts of tests will there be any attempt to conduct blind testing or will you use any form of objective measuring equipment to substantiate the findings?
It would also help to support the findings if you named the 'cheap' cables you are using and the source of the 'free' cables as there are some cables that even those of us who are unconvinced of the claims for the high-end cables would not use.
One solution might be to take the offer from HDMIhead to provide you with their cables as they are a known quantity that many people have been recommending and using at the lower end of the price spectrum.
Old 18-05-2008, 3:07 PM   #13
Trollslayer's Avatar
9,450, Level: 23
Points: 9,450, Level: 23 Points: 9,450, Level: 23 Points: 9,450, Level: 23
Activity: 27.0%
Activity: 27.0% Activity: 27.0% Activity: 27.0%
Thanks: Gave 297, Got 473
Re: new HDMI cables
It's not the way things are usually done in these forums but if anyone has access to a BERT (Bit Error Rate Tester) which is specialsied test equipment it may be possible to get measurements.
There are three main characteristics which affect cables:
1. Insertion loss - i.e. how much signal level reduction occurs
2. Dispersion - imagine two people at opposite ends of a tunnel and one shouts to te other - the sound is very 'echoey' because the sound travels along different paths thus arriving at slightly different times.
2. Jitter - same root cause as dispersion but with the effect that the edges of the signals are affected by the different paths, cancelling or reinforcing each other so it appears that signal jitters about in time.
In high speed cables if there are irregularities you can get 'lumped loads' causing larger reflections of the signal (think of a water pipe with a bend in and the resulting turbulence) which is why very thin or soft cables don't work well - they lose shape which is very important.
Generally, the digital receiver on equipment only cares if the overall effect of these is to prevent it seeing a signal at the correct time in order to sample it. Once this is done the data is purely digital.
Not sure if the clarifies or confuses things
Old 18-05-2008, 3:22 PM   #14
20,829, Level: 35
Re: new HDMI cables
Results from the BERT would be an interesting comparison of the cables performance but I'd love to have this sort of testing done in conjunction with a qualified ISF Calibrator as it is the visual effects of the cables on the display that are usually quoted.
Many of the results are usually expressed in terms of black levels and colour changes which would be extremely simple to verify if you started with a calibrated screen then observed if there were any measurable changes.
Old 18-05-2008, 3:23 PM   #15
6,996, Level: 19
Re: new HDMI cables
Hi John,
Andy H.
Hi Andy,
LOL, spelling, ppft, not a strong a point for me, I think use of apps with built in spell checking tends to make the brain lazy!
On the screen shots, the idea is to just show that there was a difference, I'd agree that you can't really use them to determin what looked best. When doing this at work I do occasionaly zoom in on the specific artifacts in question so that you don't get lost in the overall image. Its also possible to do some analysis on the images to determine if they're effectively the same, although I don't think this would come under the heading of "fun!
Cheers,
John.
Old 18-05-2008, 3:48 PM   #16
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Originally Posted by MarkTaylor View Post
....will there be any attempt to conduct blind testing or will you use any form of objective measuring equipment to substantiate the findings?
Cables will be totally blind to the viewers - just called abc etc.
objective measuring equipment - our eyes .
Will be named AFTER testing.
As it happens a number of people have offered cables as well as those I just bought in, So there will be some "GUEST" cables from those that offered - I have decided to keep those names out of the thread - so it is as blind a test as I can make it.
Old 18-05-2008, 3:59 PM   #17
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
that was done by one forum member who had to test 100+ cables. His results in his words were that there was no reason to use different cables.
However graphs seen showing the results clearly show different results - can that be seen? I dont know, I did not and wont be doing that test.
1. Insertion loss -
2. Dispersion -
2. Jitter -
I got to say your explaination of the above three items does not in my opinion really explain each item correctly - But I get the idea of what your trying to say.....
Getting sligtly off topic here......
Old 18-05-2008, 4:08 PM   #18
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Ah! now this might be possible.
My PET HATE on these forums is the people that offer ISF calibration services but DONT use ISF certified equipment.
I am NOT ISF certified, But my test equipment IS ISF Certified. So it might be possible to do this form of testing.
Sencore CP5000 ISF certified
Thoma (cant remember the number!)
The projectors will be re calibrated prior to this test, in the usual "Blended" projection system it is essential for the pair to be as identical as possible. The good news here is that CRT projectors dont change as quick with time as Digital lamp based projectors.
Old 18-05-2008, 4:20 PM   #19
20,829, Level: 35
Re: new HDMI cables
If you can do it, the potential exists for this to be the first and only test of its type that I've come across and it would certainly make a huge difference to the general utility of the results.
The old Mk1 eyeball is an amazing device but its ability to see what it wants to see at times is considerable so even if you only focused on black levels with the Sencore it would be a very useful test as people often comment on changes in this aspect when comparing cables.
It would be very good if we could move on from the long running 'oh yes they do, oh no they don't' debate as if you can show measurable differences we can start exploring why rather than just arguing about the theoretical impossibility of the difference
Old 18-05-2008, 5:43 PM   #20
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Sold to me Sir! Colourimeter tests are possible and can be done here, they take time.
My Sencore allows charting of the products so thats an area I am happy to try.
I agree, And the old Brain and Mouth in conjunction with the eye are a powerful force of persuasion
This is where the CRT projector excels at - Black levels, So should be a good test.
progress .
Old 18-05-2008, 6:18 PM   #21
3,938, Level: 14
Activity: 6.8%
Re: new HDMI cables
How does your subjective test procedure establish whether the viewers taking part in the test actually can see a difference (between HDMI cables)?
It’s no good just asking them if they can see a difference, that does not prove anything.
Alan
Old 18-05-2008, 6:32 PM   #22
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Hi Alan,
What would you suggest ?
I would like to hear what people would like to be tested, Of course there are limits to whats available but lets start with your wish list.
Andy H.
Old 19-05-2008, 3:15 PM   #23
3,938, Level: 14
Activity: 6.8%
Re: new HDMI cables
Hi Alan,
Andy H.
Andy,
I would like the subjective test (of whether different HDMI cables give different picture quality) to take the form of a double-blind ABX type test.
The two HDMI cables under test would correspond to pictures “A” and “B”, while picture “X” is the unknown and may correspond to either “A” or “B”.
The subject is free to select pictures “A”, “B” or “X” at will from their viewing position.
The subject attempts to identify “X”.
Is it “A” or is it “B” ?
The identity of “X” is then reset (by a computer program).
The subject then repeats the test for a pre-determined number of trials.
If the subject can correctly identify “X” with an adequately low probability of having just guessed the answers, then we may reasonably conclude that they can indeed detect a difference between “A” and “B”.
Alan
Old 19-05-2008, 3:21 PM   #24
TheTiffy
Posts: n/a
Re: new HDMI cables
Last Monday The Gadget Show on Five.tv tested 2 HDMI cables, one was about £25 and the other was £125. There was no difference in quality at all. They reccommended going for the cheaper HDMI cable...
Old 19-05-2008, 3:24 PM   #25
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,850, Level: 38
Points: 24,850, Level: 38 Points: 24,850, Level: 38 Points: 24,850, Level: 38
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 598, Got 1,310
Re: new HDMI cables
while definitely the way to run the test, that may be difficult to achieve.
agreed though, a 1 off, is that cable better than the last you saw is tough to sell as concrete proof.
Old 19-05-2008, 5:16 PM   #26
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
I have checked the web site and cant find this test.
Please would you provide a link , What is importand here is the length of the cable and the bandwidth it is passing.
I think we all agree on that , and that the longer the cable the more the quality matters.
.............Your post is slightly off topic so please could you provide the link in another thread for others to comment. Thank you.
Old 19-05-2008, 5:23 PM   #27
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Andy,
I would like the test take the form of a double-blind ABX type test.
Alan
OK, Firstly that double blind test is actually VERY easy to setup, So I will consider it.
This of course assumes that we can see a differance.
There is every chance (being open minded) that no differance is seen, If thats th case then no double blind test is available. I hope every one agree on that ?
Mossym - I have NEVER just done single tests of anything, to put this in perspective in "my world" of home cinema just over 150 hours were spent on colour balance of my two previous projectors - I am very patient and set out to achieve the best I can.
For those that have an hour to kill please read through my home cinema thread in my signature - That will give a better insight to the guy behind the name . You never know there might be something of use to you in there .
Old 19-05-2008, 5:31 PM   #28
TheTiffy
Posts: n/a
Re: new HDMI cables
Apologies, I thought this was about whether different HDMI cables give different picture quality.
Old 19-05-2008, 5:33 PM   #29
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
For the record..........
There are now FIVE well known brands of cables that will be included in the initial test (there might be a sixth I am considering that at the mo)
Old 19-05-2008, 5:47 PM   #30
Mad Mr H's Avatar
20,266, Level: 34
Re: new HDMI cables
Sort of, but your post does not provide a link that I can see what was said and what was tested. So the result might be "buy £25 not £125 cable" but the situation is not mentioned.
Plasma tv, LCD, projector, source, resolution, distance, with audio, without audio, sure I missed some.
Im sure you meant your post to be informative but I hope you now see that we are missing the info related to the statement.
There are two main camps in this area of the forum, those that believe "most" HDMI cables give the same results and those that believe there is a visual difference.
There are many other trains of thought as well, but I think it fair to say ALL groups like to see full and transparent information to back up each statement.
General thoughts about this can be found in many existing threads.
This thread is slightly more specific in that I am not repeating what others have said, I am setting out to test IF there is a difference in MY system. My previous A/B testing did show a difference that others questioned so this time round I will try and offer more than just "thats what I saw" .
Thread Closed
