Question about HDMI cable
Old 07-05-2008, 12:07 PM   #1
3,101, Level: 13
Points: 3,101, Level: 13 Points: 3,101, Level: 13 Points: 3,101, Level: 13
Question Question about HDMI cable
i want to buy a HDMI cable,how should I know if the cable is 1.3 Ver. HDMI?
i mean support HDMI 1.3.
Old 07-05-2008, 12:53 PM   #2
Conspicuous Member
IAN P's Avatar
18,180, Level: 32
Points: 18,180, Level: 32 Points: 18,180, Level: 32 Points: 18,180, Level: 32
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 125, Got 1,022
Re: Question about HDMI cable
How long is the lead that you need?
Look here.
http://www.tvcables.co.uk/cgi-bin/tv...1.3-cable.html
Old 07-05-2008, 1:52 PM   #3
3,101, Level: 13
today, my friend gives me a HDMI cable, how can I know the cable is support 1.3 ver.?
Old 07-05-2008, 10:49 PM   #4
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Just use it, there is no other way to tell.
There is nothing visible about a cable that can help you as 1.3 merely requires that it can handle a higher data rate.
Most short cables that are properly made will handle the requirements of 1.3 perfectly well regardless of if they are actually labelled as such.
Old 07-05-2008, 10:54 PM   #5
Heavysalad's Avatar
5,747, Level: 17
Points: 5,747, Level: 17 Points: 5,747, Level: 17 Points: 5,747, Level: 17
Thanks: Gave 22, Got 93
You can't realisticaly find out or know unless of course the cable has it printed on it somewhere like this Neet one ... HDMI cable 1.3
Which goes someway to show you that its not really all that important if you can't tell ?
a 1.2 HDMI cable is compatable with and will work fine with 1.3 devices like a PS3 and newer TVs anyway so no worries ... especialy if your friend has 'given' it to you as that makes it a bargain
Edit: ^^^ what he said ! Double post there
