HDMI - a basic guide
Old 19-02-2007, 10:42 AM   #1
Founder
Stuart Wright's Avatar
146,883, Level: 92
Points: 146,883, Level: 92 Points: 146,883, Level: 92 Points: 146,883, Level: 92
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 902, Got 4,625
This useful guide (in PDF format) was sent to me by Chris Moseley from Yamaha with the accompanying message:
May be of some use to members of your forum. HDMI is very mis understood in the market place and this guide is an unbiased document which should help prevent people from buying without really understanding what they are getting. We wrote this for our dealers as they tend to understand a bit and make up the rest with what they already know about other connection types and common sense, however HDMI doesn't really follow the rules of other connections or common sense!
It's not really pro Yamaha and isn't advertising our products, all though there are a few photos of Yamaha products.
Thanks Chris.
Hope you folks find it useful.
flash_uk (01-01-2008), JackM (28-12-2007), joffy1780 (19-02-2007), p0kerm0n2004 (20-02-2007), Tejstar (21-02-2007)
Old 19-02-2007, 11:00 AM   #2
Illustrious Member
Abbeygoo's Avatar
19,856, Level: 34
Points: 19,856, Level: 34 Points: 19,856, Level: 34 Points: 19,856, Level: 34
Activity: 10.5%
Activity: 10.5% Activity: 10.5% Activity: 10.5%
Thanks: Gave 1,936, Got 2,084
Re: HDMI - a basic guide
Interesting in the section titled : "misconceptions" - the guide states that not all cables are of the same quality. This debate appears frequently on these forums where people believe that all HDMI cables of, say 1m, are the same quality yet retailers / manufacturers would have you believe differently.
Interesting read, thanks Stuart.
Old 19-02-2007, 11:35 AM   #3
KyleS1's Avatar
9,020, Level: 22
Points: 9,020, Level: 22 Points: 9,020, Level: 22 Points: 9,020, Level: 22
Activity: 60.6%
Activity: 60.6% Activity: 60.6% Activity: 60.6%
Thanks: Gave 190, Got 221
Top read that! I was completely uneducated on HDMI etc before reading that, and it really makes things a lot clearer.
I'll understand a lot more of the posts in this forum now!
Old 19-02-2007, 2:55 PM   #4
loz loz is offline
Conspicuous Member
30,195, Level: 42
Points: 30,195, Level: 42 Points: 30,195, Level: 42 Points: 30,195, Level: 42
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 281, Got 815
It depends how you define "quality".
In the report, Yamaha state
HDMI cables are available in different qualities. These will, just as other cables do, vary the quality of the passing signal. Some cables can carry high bandwidth data over a greater distance than others as a consequence of this degradation.
It is true to say that "HDMI cables are available in different qualities."
E.g. they may differ in terms of construction quality or material quality.
The consequence of the construction and material quality is as Yamaha state, "...Some cables can carry high bandwidth data over a greater distance than others as a consequence..."
However, this is not the same as saying "HDMI cables produce different picture quality."
I don't think anyone argues that an expensive QED HDMI cable is better constructed or made of better materials than the freebie that comes in the box with some equipment. However, people do argue about whether using the QED HDMI cable results in a better PQ compared to the freebie cable when used at short lengths...
Abbeygoo (19-02-2007)
Old 19-02-2007, 6:07 PM   #5
Conspicuous Member
recruit's Avatar
26,913, Level: 39
Points: 26,913, Level: 39 Points: 26,913, Level: 39 Points: 26,913, Level: 39
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
Thanks: Gave 521, Got 593
I have created a link in the FAQs thread sticky at the top of this page, thanks Stuart
Old 19-02-2007, 6:35 PM   #6
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Its not perfect (ineed to check some things i dont have with me) but fair play to yamaha uk and chris for producing and releasing this document. Hopefully the industry is realising that better educated of frontline staff is required and urban myths need dispelling
Old 19-02-2007, 8:56 PM   #7
cjb cjb is offline
4,876, Level: 16
Points: 4,876, Level: 16 Points: 4,876, Level: 16 Points: 4,876, Level: 16
Thanks: Gave 27, Got 1
very interesting info, especially as I bought a YAMAHA 757se thinking it would convert evrything to Hdef.
BUT, one thing the guide didn't say was the answer to my question...
Is HDMI cabling designed to be HOTSWAP ?. and if not, do both ends need to be 'OFF' b4 pluggin ???
I wonder how many different answers I get
and for that matter.. is COMPONENT cable HOTSWAP
Old 20-02-2007, 9:08 AM   #8
Davy's Avatar
4,043, Level: 14
Points: 4,043, Level: 14 Points: 4,043, Level: 14 Points: 4,043, Level: 14
Thanks: Gave 22, Got 27
An interesting read, which certainly answered a few questions and dispelled a few myths. As to the quality (and subsequent cost) of cabelling is seems to confirm my own experiences (yes I also am taken in by the manufacturers and buy decent cables); that when replacing audio cables, I can definately hear an improvement but when replacing video cables, errr I think I can see the difference.
Old 20-02-2007, 8:21 PM   #9
Assured Advertiser
63,997, Level: 61
HDMI has a hot swap pin assigned (not sure if this is to enable or disable hot swapping)component is hot swapable
Dann'sTheMan (30-03-2007)
Old 20-02-2007, 8:34 PM   #10
nikyzf
Posts: n/a
This is from a cable maker's site, but I found it very informative.
<http://www.bluejeanscable.com/articles/whats-the-matter-with-hdmi.htm>
Old 21-02-2007, 12:28 PM   #11
Eminent Member
Tejstar's Avatar
126,891, Level: 86
Points: 126,891, Level: 86 Points: 126,891, Level: 86 Points: 126,891, Level: 86
Thanks: Gave 408, Got 993
A very interesting read - thanks Stuart and Chris.
Old 21-02-2007, 10:33 PM   #12
cjb cjb is offline
4,876, Level: 16
Re HDMI is/isn't hot swappable
So thats one for the maybe it is, maybe it isn't then.
Old 22-02-2007, 8:21 AM   #13
Assured Advertiser
Joe Fernand's Avatar
36,531, Level: 46
Points: 36,531, Level: 46 Points: 36,531, Level: 46 Points: 36,531, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
Hello cjb
HDMI is billed as 'hot swappable' - though:
01. You definitely 'see' a spark with lots of kit if your working in the dark.
02. HDCP is not robust enough on lots of kit to survive a cable disconnect/reconnect and you have to reboot the Display and or Source before things talk to each other again.
Where possible I'd advise you to not hot swap.
Joe
Old 22-02-2007, 8:10 PM   #14
cjb cjb is offline
4,876, Level: 16
Thanks for that.. I assumed it wasn't hotswap but had not seen it in black' n' white. So evryone better "be careful out there".
