15 or 20m hdmi cable recommendations please
Old 16-11-2009, 12:45 AM   #1
5,315, Level: 17
Points: 5,315, Level: 17 Points: 5,315, Level: 17 Points: 5,315, Level: 17
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 207, Got 121
hi,
i hope someone can ppoint me in the right direction as to which hdmi cable make is good for sending 1080p signals at 15 or 20m lenght without degradation, if not, are there any solutions?
connection will be sony vw60 to a HTPC for video only.
thanks in advance
dean
Old 16-11-2009, 9:47 AM   #2
Assured Advertiser
Joe Fernand's Avatar
36,538, Level: 46
Points: 36,538, Level: 46 Points: 36,538, Level: 46 Points: 36,538, Level: 46
Activity: 20.3%
Activity: 20.3% Activity: 20.3% Activity: 20.3%
Thanks: Gave 205, Got 1,344
Re: 15 or 20m hdmi cable recommendations please
Hello dean999
Up to 15m there are various 'cable' options - some Amplified some non amplified;
Media Factory - Bettercables HIgh Speed CAT2 HDMI cables, 1m to 12m.
Over 15m I'd consider HDMI over Dual CAT6 - far less problematic than a 'cable' solution;
Media Factory - Octava HDMICAT-UK, HDMI over CAT5 extender
Media Factory - Octava HDOCAT, HDMI + Optical 5.1 over CAT5 Extender inc. IR Passthru
Joe
dean999 (16-11-2009)
Old 16-11-2009, 1:15 PM   #3
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Points: 3,397, Level: 13 Points: 3,397, Level: 13 Points: 3,397, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 3, Got 100
Hello dean999,
Please visit
HDMI Ivuna Cables
UKHDMI is an Assured Advertiser.
Cablesson ¦ Octava
HDMI Cable - We won the award of the most active company at CEDIA 08.
Old 17-11-2009, 11:34 AM   #4
Assured Advertiser
LINDY Chris's Avatar
2,028, Level: 10
Points: 2,028, Level: 10 Points: 2,028, Level: 10 Points: 2,028, Level: 10
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 4, Got 63
We have one that is only one CAT5/6* cable
HDMI CAT5e/6 Extender 35m | HDMI | Extenders | Audio / Video | LINDY UK
* I would recommend CAT6
Best Regards
Chris
LINDY Electronics. Computer, Audio / Video and Home Cinema Cables & Accessories. Over 2,500 products in stock.
Established in 1932. ISO 9001 Certified.
www.lindy.co.uk | Follow us on twitter @LINDYUK and Facebook
dean999 (17-11-2009)
Old 17-11-2009, 5:15 PM   #5
5,315, Level: 17
Activity: 1.7%
Originally Posted by Joe Fernand View Post
Hello dean999
Joe
hi joe
thanks for your advice. with regards to the octava cat5 extender, are the cat 6 patch cables a standard configuration , and do you supply various lenghts of cat 6 cables, prices for 7,8, 9 metres please.
many thanks
dean
Old 23-11-2009, 9:52 PM   #6
1,200, Level: 7
Points: 1,200, Level: 7 Points: 1,200, Level: 7 Points: 1,200, Level: 7
Thanks: Gave 12, Got 15
Hi Dean I use a budget 15m HDMI cable for my Sony HD PJ with no problems at all. If you go the cat6 extender route probably you only need one cable as you only need the picture.
Old 23-11-2009, 10:01 PM   #7
Assured Advertiser
36,538, Level: 46
Activity: 20.3%
You require 2 x CATx cables - with HDMI the audio stream is buried in the video stream; the second cable carries the EDID and HDCP info so without it you wont get an image.
Joe
Old 23-11-2009, 10:20 PM   #8
1,200, Level: 7
Joe, thanks for clearing that up.
Joe Fernand (24-11-2009)
Old 24-11-2009, 10:31 PM   #9
5,315, Level: 17
Activity: 1.7%
hi newbie, thanks for your reply.
placed my order for the octava hdmi 1.3 extender on moday morning( the extender boxes are about 2 matchboxes long), rec;d it at 8am this morninig,
tested it a pair of 10m cat 6 utp patch cables for about an hour on various films and it works fine, thanks to joe fernand at the media factory.
regards
dean
Joe Fernand (25-11-2009)
