Which HDMI Splitter to buy??
Old 07-11-2009, 1:37 PM   #1
1,496, Level: 8
Points: 1,496, Level: 8 Points: 1,496, Level: 8 Points: 1,496, Level: 8
Hi all,
This is my first time posting on the forum, although been reading posts for a while.
I suspect that this question may have already been answered as well but would be grateful for any advice anyone can give me.
I am looking to buy a HDMI spliter preferably 1 input x 2 output
The 1 input is my PS3, the first output will be a HD monitor (PS3 games) and the second output will be a HDTV via an onkyo 577 AV Receiver (PS3 Games and Blu-Ray Movies).
I've been looking at different options, makes and brands and can't seem to decided what would be best.
I don't really want to spend anymore than £70 - £75 ish
Thank you for any help and advice that can be given.
Old 07-11-2009, 2:40 PM   #2
Conspicuous Member
shahedz's Avatar
13,126, Level: 27
Points: 13,126, Level: 27 Points: 13,126, Level: 27 Points: 13,126, Level: 27
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 1,382, Got 723
Re: Which HDMI Splitter to buy??
check this out
Neet® - 2 Way HDMI SPLITTER BOX 1x2 Port - Active: Amazon.co.uk: Electronics & Photo
obsolete316 (21-08-2010)
Old 10-11-2009, 3:24 PM   #3
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Points: 3,397, Level: 13 Points: 3,397, Level: 13 Points: 3,397, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 3, Got 100
Hello PhoenixFoster
How about £39.99??
Cablesson 1x2 Mini HDMI Splitter
UKHDMI is an Assured Advertiser.
Cablesson ¦ Octava
HDMI Cable - We won the award of the most active company at CEDIA 08.
Old 10-11-2009, 3:41 PM   #4
19,432, Level: 33
Points: 19,432, Level: 33 Points: 19,432, Level: 33 Points: 19,432, Level: 33
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 19, Got 13
Excellent product - it just works with no fuss!!
Be aware though that I had problems using one with an amstrad sky hd box but it may have been sorted with a power supply (email neet for info) - it was easier to get sky to replace the (pants) amstrad for a pace!
Old 10-11-2009, 10:13 PM   #5
1,496, Level: 8
Originally Posted by Baldybouncer View Post
bought the Neet one, which arrived today, haven't tested it fully but initial tests look really good ..... thanks for all the advice
Old 14-11-2009, 3:30 PM   #6
2,777, Level: 12
Points: 2,777, Level: 12 Points: 2,777, Level: 12 Points: 2,777, Level: 12
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 33, Got 26
Originally Posted by HDMIHead View Post
Hello PhoenixFoster
How about £39.99??
I Wouldn't recommend this one.
I have my amp outputting HDMI into this and then it splitting off to the television and the projector. However the image will only display on the TV if I have both the television and projector turned on. So I have to turn on the projector so the image appears on the television and then turn off the projector just to have a single image on the TV. Terrible.
Old 14-11-2009, 6:57 PM   #7
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Activity: 3.4%
Hello nonsoloinglese,
Is the amp Onkyo?
Cablesson ¦ Octava
Old 14-11-2009, 7:01 PM   #8
2,777, Level: 12
Activity: 0.7%
No, it's a Yamaha DSP-763.
Old 15-11-2009, 9:23 AM   #9
19,432, Level: 33
Activity: 3.8%
The neet one will display to 2 or 1 devices without needing to switch either on/off - As I said it just works! - And its cheaper!
Old 29-11-2009, 1:31 PM   #10
3,506, Level: 13
Points: 3,506, Level: 13 Points: 3,506, Level: 13 Points: 3,506, Level: 13
Thanks: Gave 13, Got 8
The Neet splitter works superbly well but I have discovered that I need to use the external power supply..... when one hdmi output is not handshaked to tv...in other words if one tv is taking a dvd or bd input direct to tv then the other the hdmi cable from the sky hd box via the splitter does not sync properly. Without the ext power I loose sound on the other hdmi cable or sometimes sound and vision. Plugging in the ext power sorted this!
Old 03-12-2009, 3:38 AM   #11
MI55ION's Avatar
15,074, Level: 29
Points: 15,074, Level: 29 Points: 15,074, Level: 29 Points: 15,074, Level: 29
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 400, Got 355
Of course you need to use it with the supplied power adaptor, how else is it supposed to work?
Old 03-12-2009, 9:50 AM   #12
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Some switches and splitters are designed to leach power from the HDMI cable but this is a bad idea and not what the power line in the HDMI spec was intended for.
If anyone has problems with such a device then the first thing to do is always attach the external power supply.
Old 03-12-2009, 9:55 AM   #13
Assured Advertiser
Joe Fernand's Avatar
36,531, Level: 46
Points: 36,531, Level: 46 Points: 36,531, Level: 46 Points: 36,531, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
A bit more info here - For HDMI, Power is Still an Issue - CE Pro Magazine Article from CE Pro
Joe
Old 03-12-2009, 6:21 PM   #14
MI55ION's Avatar
15,074, Level: 29
Activity: 8.3%
disregard:
Just seen this under the product description:
Auto Power over HDMI (5v DC UK PSU Included should it be required).
Old 20-01-2010, 10:12 AM   #15
3,926, Level: 14
Points: 3,926, Level: 14 Points: 3,926, Level: 14 Points: 3,926, Level: 14
Thanks: Gave 4, Got 0
I was just about to order the cableson splitter, but saw the link for the neet, and prefer independent viewing without having the need for both targets to be on.
Taking rock band playing to the extreme!! Going to be having main plasma screen on for the band and having a smaller screen to my Roland drum kit programmed in to play on't drums too :D. Cash back!
Old 20-01-2010, 3:21 PM   #16
2,777, Level: 12
Activity: 0.7%
I purchased the Neet but now my XBOX 360 has HDCP issues with my television/projector. Does the cost of the splitter determine whether these issues occur?
Old 20-01-2010, 3:28 PM   #17
Assured Advertiser
21,242, Level: 35
Points: 21,242, Level: 35 Points: 21,242, Level: 35 Points: 21,242, Level: 35
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 58, Got 205
Its not the cost that matters, it's the quality.
Quality costs more than cheap stuff though
Try the Octava HDDA12.
Mark.
markgrantcables.co.uk --- Highest quality products and service --- Cables, OPPO Blue Ray region free , Focal speakers - Squeeze-upgrade.com PSU- Genuine UK business ( Assured Advertiser)
Old 20-01-2010, 4:03 PM   #18
Assured Advertiser
36,531, Level: 46
Activity: 20.9%
Many factors contribute to system compatibility - there is a lot going on behind the scenes within the HDMI pipeline.
The retail price of a unit is not a good indicator of what will work for you and what wont.
As you've found out even 'recommendations' can be a bum steer with HDMI - some low cost gear will work for some folk but wont be as universally system compatible compared with other designs.
Its also worth noting that some designs do give you more chance of success if the manufacturer/supplier has the ability to load various Firmware options to enable you to find a work around where you are facing compatibility issues.
Joe
Old 20-01-2010, 6:17 PM   #19
1,496, Level: 8
Hi all,
Just thought I'd update this post with a quick review of the Neet HDMI splitter. I have the Neet splitter about 1m away from PS3 and split the single between a viewsonice 24" hdmi monitor (using a cheap 1m HDMI cable) and my 32" Panasonic Viera TV going via a Onkyx AV Reciever using better quality HDMI Cables.
Have had no issues at all with the product it works perfect for what I need I can play my PS3 on my monitor or TV and watch Blu-Ray's on the TV with decent surround sound ...... would recommend this lil product, if it wasn't for the red light that appears when it is active I wouldn't even know it is there. Also haven't needed to use the power adapter that can with it either, actually this is my only grumble if I did need to use the power adapter the cable on the plug is tiny maybe a metre in length but this is the only issue I have found to date.
Old 15-05-2010, 5:43 PM   #20
1,994, Level: 10
Points: 1,994, Level: 10 Points: 1,994, Level: 10 Points: 1,994, Level: 10
Just bought one of these neet 1x2 splitters
Plugged in the 3 HDMI leads and it works fine with no power supply [it was supplied though]
My set up is a 46 inch panasonic plasma 1m cable and a philips 23 inch lcd on a 10 m cable
The picture on both tv's is stunning
And they can be on or off for any to work
And only £30 from ebay
And still using the mouse on the co-axial cable to change channels
Old 15-05-2010, 8:31 PM   #21
2,576, Level: 11
Points: 2,576, Level: 11 Points: 2,576, Level: 11 Points: 2,576, Level: 11
Thanks: Gave 30, Got 3
Looking for an HDMI splitter as well.
The length of run to the second tv is just under 10 meters, which I was going to use a 10 meter HDMI cale.
Anybody know if the neet would do the job, or for this length of run would I be better running Cat 5e/6 through baluns? instead of a long HDMI cable?
Old 16-05-2010, 11:15 AM   #22
DrH DrH is offline
2,341, Level: 11
Points: 2,341, Level: 11 Points: 2,341, Level: 11 Points: 2,341, Level: 11
Thanks: Gave 34, Got 51
This was the one i bought:
HDMI Splitter 2 Way Only £37.99 at TVCables
Running to my pj with a 9M cable and 2M to my plasma, never had a problem with it. I have always used the power supply.
DrH
kmm66d (16-05-2010)
Old 27-05-2010, 4:01 PM   #23
803, Level: 6
Points: 803, Level: 6 Points: 803, Level: 6 Points: 803, Level: 6
Thanks: Gave 7, Got 1
Hello
I would like to know what is the deference between an HDMI Splitter & an HDMI Switcher ?
Old 27-05-2010, 4:16 PM   #24
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,851, Level: 38
Points: 24,851, Level: 38 Points: 24,851, Level: 38 Points: 24,851, Level: 38
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 598, Got 1,310
DrH
same here, i have one and it has always worked perfectly
I also have an octavia 5:2 from Joe and it works perfectly as well, although obviously in a different setup
