decent quality 'Right-Angle' HDMI cables?
Old 29-10-2009, 6:59 PM   #1
1,558, Level: 9
Points: 1,558, Level: 9 Points: 1,558, Level: 9 Points: 1,558, Level: 9
Activity: 3.2%
Activity: 3.2% Activity: 3.2% Activity: 3.2%
Thanks: Gave 6, Got 1
Are there any decent quality (not a big believer in 'high' quality HDMI cables per se) right angle HDMI cables?
Spoke to a chap today who said that there arnt many out there at the moment.
Wall mounting my panasonic G10 42" and it seesm that the hdmi fittings are going to force me to mount the TV a fair bit further out from the wall than I wanted too
many thanks!
Old 29-10-2009, 7:17 PM   #2
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Points: 3,397, Level: 13 Points: 3,397, Level: 13 Points: 3,397, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 3, Got 100
Re: decent quality 'Right-Angle' HDMI cables?
Hello Wump,
Please checkout HDMI Male to Female 200mm Short Cable works much better compared to right angle adapter.
UKHDMI is an Assured Advertiser.
Cablesson ¦ Octava
HDMI Cable - We won the award of the most active company at CEDIA 08.
Old 29-10-2009, 7:27 PM   #3
1,558, Level: 9
Activity: 3.2%
Hi wasnt thinking about an adapter just a 3metre cable. Wont an adapter lose quality of the feed?
Old 29-10-2009, 7:30 PM   #4
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Activity: 3.4%
Hello Wump,
The cable/adapter can easily bend 90 degrees, i have tested it my self bending it to 140. You can use any standard hdmi cable to connect to it. As for losing quality No.
Cablesson ¦ Octava
Old 29-10-2009, 7:48 PM   #5
6,106, Level: 18
Points: 6,106, Level: 18 Points: 6,106, Level: 18 Points: 6,106, Level: 18
Thanks: Gave 1, Got 20
Hi Wump,
Here's a few right angle cables for you:-
Right Angle Hdmi Cable - In Stock at www.tvcables.co.uk UK & Worldwide Shipping
Andy.
Old 30-10-2009, 9:48 AM   #6
1,558, Level: 9
Activity: 3.2%
Hi HDMIHead
What exactly does that cable do? lokks like a normal hdmi cable
Has anyone got any opinions on right angle HDMI quality?
Wump
