Is it possible to run 2 (or more) HDMI devices in to one cable?
Old 29-10-2009, 12:24 PM   #1
6,235, Level: 18
Points: 6,235, Level: 18 Points: 6,235, Level: 18 Points: 6,235, Level: 18
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 7, Got 7
Just checking into HDMI cables. I need a 10m one and prices including delivery seems to be around the £100 delivered.
I can do without buying two of these.
Does a device exist that would allow me to plug my PS3 and Sky HD into some sort of multi input box that then feeds out to the one single £100 cable to my screen.
I understand I will only be able to view one at a time, thats no prob.
Does a device such as this exist?
Old 29-10-2009, 12:35 PM   #2
StevieBuck's Avatar
8,308, Level: 21
Points: 8,308, Level: 21 Points: 8,308, Level: 21 Points: 8,308, Level: 21
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 28, Got 585
Re: Is it possible to run 2 (or more) HDMI devices in to one cable?
Use an HDMI switch:
HDMI Switch - www.tvcables.co.uk
Old 29-10-2009, 12:49 PM   #3
2,383, Level: 11
Points: 2,383, Level: 11 Points: 2,383, Level: 11 Points: 2,383, Level: 11
Thanks: Gave 44, Got 9
Also you don't need to spend £100 there are a few that advertise on this forum that do good value ones for about £35 off the top of my head
Old 29-10-2009, 2:41 PM   #4
6,235, Level: 18
Activity: 2.7%
Thanks stevie
Hi ben. £30 for a 10 meter HDMI is ok? I was worried about picture deterioration over such a long run. Hence paying more.
Old 29-10-2009, 7:21 PM   #5
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Points: 3,397, Level: 13 Points: 3,397, Level: 13 Points: 3,397, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 3, Got 100
Hello Mickey123,
Price is no way to judge a product... Maybe you can provide a link to the product and i am sure forum members will give you some feedback.
UKHDMI is an Assured Advertiser.
Cablesson ¦ Octava
HDMI Cable - We won the award of the most active company at CEDIA 08.
Old 29-10-2009, 11:31 PM   #6
6,235, Level: 18
Activity: 2.7%
HDMI to DVI Cables at Blue Jeans Cable
about halfway down under...
BJC Series-1 Belden Bonded-Pair HDMI to DVI Cables:
Our best cable for distance runs.
I got 40 ft one
Old 30-10-2009, 8:41 AM   #7
4,395, Level: 15
Points: 4,395, Level: 15 Points: 4,395, Level: 15 Points: 4,395, Level: 15
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 47, Got 70
Originally Posted by Mickey123 View Post
PRO SIGNAL|PSG01043|LEAD, HDMI PLUG TO PLUG 10M | CPC
