| I'm having terrible problems with this
HELP!!!!!
I have a PS3 and V+ box connected (I wish!) via a 10m HDMI cable.
Initially I got a cheap 10 m cable (£10 -10m cable to TV is a EX-Pro Premium 10m Gold HDMI to HDMI Lead cable. HD Support 1080p – HDMI 1.3 (125283-49) Compliant. On the cable it says:- E301195 RJ AWM STYLE 20276 80 dec C RW-1 PAK HENG REV 1.3 HDMI Cable. It has a suppressor on each end).
TV connected direct to the V+ box the 10m cable was fine.
Connected direct to the PS3 the cable was ok but the signal wasn't very stable.
I connected via a auto switch and two 1 m cables (provided by Virgin) and although the switch detected which source was on - no picture at the TV.
So I tried a switch with a remote control and a power supply - that didn't work either, so I tried a manual switch. That was ok with the V+ box, though there were the odd white flickery pixels if you looked up close, but the PS3 didn't work - so I bought a better (£40) cable:-
Neet® Black Line - 10m HDMI to HDMI Cable - ** GENUINE 24awg ** - HIGH-SPEED 10.2Gbps - v1.3 - 1080p 1440p 1600p Full HD - ADVANCED HDMI LEAD
That was so chunky it wouldn't fit behind the TV on the wall so I had to purchase a 90 degree connector (a 'Monster' one).
Now, connected direct the TV is fine but the PS3 is unusable, loads of white flickery pixels and signal drops in and out (worse than the cheap cable!).
It seems the PS3 signal is weaker than the V+ box and the new more expensive cable is inferior, or is the worse signal at the TV due to the 90 degree connector I have to use with this cable?
Any ideas please? Can you boost the HDMI signal with an amplifier?
Dazzer
