HDMI switcher help
Old 26-10-2009, 8:32 PM   #1
6,342, Level: 18
Points: 6,342, Level: 18 Points: 6,342, Level: 18 Points: 6,342, Level: 18
Activity: 8.4%
Activity: 8.4% Activity: 8.4% Activity: 8.4%
Thanks: Gave 148, Got 298
HDMI switcher help
can a 2 input/1 output switcher be used in reverse 1 input/2 output? asking for a friend who wants to connect sky HD to his TV and his projector.
Regards Martin
Old 26-10-2009, 10:53 PM   #2
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Re: HDMI switcher help
Slightly odd answer, but no, not if it is a properly constructed device, possibly yes if it is badly made.
mjbtin (27-10-2009)
Old 27-10-2009, 6:00 AM   #3
6,342, Level: 18
Activity: 8.4%
Thanks for the reply Mark,its a cheap manual switcher from argos I will let him have it to try.
If it does not work can a 1 input/2 output switcher be purchased?
Regards Martin
Old 27-10-2009, 8:43 AM   #4
Assured Advertiser
Joe Fernand's Avatar
36,531, Level: 46
Points: 36,531, Level: 46 Points: 36,531, Level: 46 Points: 36,531, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
Hello pdbmjb
A MarkTaylor says some of the very low cost 2x1 Switch units can be reverse wired and used as a 1x2 Output switch - though results can be pretty hit and miss.
A 1x2 Distribution Amp (with external power) is what HDMI.org recommend - lots of options available; Media Factory - Octava HDDA12-UK, 1x2 HDMI distribution amp.
Joe
mjbtin (27-10-2009)
Old 28-10-2009, 9:15 AM   #5
7,884, Level: 21
Points: 7,884, Level: 21 Points: 7,884, Level: 21 Points: 7,884, Level: 21
Thanks: Gave 15, Got 36
Hi pdbmjb, I recently borrowed one of these off a friend and it seems to work really well, not a switch but will output to 2 devices.
Neet® - 2 Way HDMI SPLITTER BOX 1x2 Port - Active: Amazon.co.uk: Electronics & Photo
Hope that helps
Slingshot
mjbtin (29-10-2009)
Old 29-10-2009, 5:33 PM   #6
6,342, Level: 18
Activity: 8.4%
My mate tried the slx switcher in reverse and it worked,he didnt need a switcher with built in amplifier as his projector is the same end of the room as his tv and sky hd box.
Thanks again for all your replies.
Regards Martin
