HDMI Scart
Old 26-10-2009, 3:22 PM   #1
1,559, Level: 9
Points: 1,559, Level: 9 Points: 1,559, Level: 9 Points: 1,559, Level: 9
HDMI Scart
I have a new HD TV The home cinema system does not have an HDMI out. I can connect by Scart fine, but as the Scart is powered everytinme I swithch on the tV and sky (conencted by HDMI) then switch on the home cinema to get sound it kicks over to the scart av signal. Can you get a scart that is not 'powered' or a cable that is Scart to HDMI to stop this annoying thing happening
Old 26-10-2009, 11:16 PM   #2
Jamie's Avatar
10,760, Level: 24
Points: 10,760, Level: 24 Points: 10,760, Level: 24 Points: 10,760, Level: 24
Thanks: Gave 93, Got 573
Re: HDMI Scart
If you are happy to open the scart connecter then snipping the wire to pin 8 will do the job.
See here:
Leads Direct - SCART Wiring
Old 27-10-2009, 10:17 AM   #3
1,559, Level: 9
Re: HDMI Scart
thanks jimbob
