Which HDMI? QED or Sony?
Old 16-10-2009, 8:41 PM   #1
3,056, Level: 13
Points: 3,056, Level: 13 Points: 3,056, Level: 13 Points: 3,056, Level: 13
Thanks: Gave 3, Got 2
Good evening all! I need to get a hdmi cable for connecting LCD hdtv to ps3.
Whilst some people have been telling me they are all the same I will go for a mid range £50ish pounds. I have been looking at QED and the top Sony one. But i really cant decipher the description. Of these 3 which is best? Thanks
QED PS3 cable
QED Performance cable
Sony HD30 Premium cable
Old 16-10-2009, 8:59 PM   #2
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Points: 3,397, Level: 13 Points: 3,397, Level: 13 Points: 3,397, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 3, Got 100
Re: Which HDMI? QED or Sony?
Hello Legends,
Out of Sony and QED, it should be QED.
UKHDMI is an Assured Advertiser.
Cablesson ¦ Octava
HDMI Cable - We won the award of the most active company at CEDIA 08.
Old 16-10-2009, 8:59 PM   #3
drivinscool's Avatar
7,095, Level: 20
Points: 7,095, Level: 20 Points: 7,095, Level: 20 Points: 7,095, Level: 20
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 157, Got 157
QED PS3 cable
Listen to the advice, a £10 one will do exactly the same job as a £50 one
Old 17-10-2009, 2:52 PM   #4
3,056, Level: 13
Do all hdmi 1.3 cables support Deep Colour?
Old 17-10-2009, 8:12 PM   #5
LicensedTaximan's Avatar
5,175, Level: 17
Points: 5,175, Level: 17 Points: 5,175, Level: 17 Points: 5,175, Level: 17
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 148, Got 117
The latest Home Cinema Choice has an article about the deep colour subject, what good timing for your question.
Old 17-10-2009, 10:36 PM   #6
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Describing a cable as 1.3 is confusing anyway as it is the equipment at each end that needs to support the specific features of 1.3, not the cable in the middle.
Look for one marked as 'Cat 2' or 'high-speed' and don't worry about the numbers.
Old 17-10-2009, 10:58 PM   #7
loz loz is offline
Conspicuous Member
30,195, Level: 42
Points: 30,195, Level: 42 Points: 30,195, Level: 42 Points: 30,195, Level: 42
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 281, Got 815
Cables don't 'support' anything. They just pass the signal from one device to the other.
Every HDMI cable has exactly the same wiring.
For short cable lengths a sub £10 HDMI cable will do just as good a job as a £100 plus one.
Old 18-10-2009, 11:46 AM   #8
4,597, Level: 16
Points: 4,597, Level: 16 Points: 4,597, Level: 16 Points: 4,597, Level: 16
Thanks: Gave 4, Got 1
I bought some of the thatcable.com HDMI cables that got 5 stars in What Hi-Fi. They're only £4.99 for a 1.5m cable. I was pleasantly surprised by the high quality of the construction. The cable is braided and the connectors are gold plated. I find it hard to believe that the £50 QED cables would make any difference.
By the way, at the same time I also bought some of the Fisual Pro Install Series digital optical cables recommended on this forum. They were £5.98 for 2m. Again, I was very impressed. They're of similar build quality to the QED coaxial digital cable I already own and much better than the Ixos digital optical digital cable I already own.
Old 18-10-2009, 11:58 AM   #9
Greg's Avatar
38,927, Level: 48
Points: 38,927, Level: 48 Points: 38,927, Level: 48 Points: 38,927, Level: 48
Activity: 63.9%
Activity: 63.9% Activity: 63.9% Activity: 63.9%
Thanks: Gave 178, Got 1,396
They don't, that's why. No difference at all. Except the person who bought them has just chucked £40 down the drain.
Old 19-10-2009, 11:25 AM   #10
3,537, Level: 13
Points: 3,537, Level: 13 Points: 3,537, Level: 13 Points: 3,537, Level: 13
Thanks: Gave 114, Got 74
I got excellent service from here HDMI Cable, HDMI over IP, HDMI over Cat5, HDMI Mini Cable, HDMI Switch, HDMI Splitter and HDMI Matrix and would recommend them.
got **** service from a certain place that sells oppo.
Old 19-10-2009, 11:26 AM   #11
3,589, Level: 14
Points: 3,589, Level: 14 Points: 3,589, Level: 14 Points: 3,589, Level: 14
Thanks: Gave 12, Got 72
Taken from the second QED link:
"The HDMI-P is a stunning product. The detail it gives you is awesome. Images come to life, showing pin-sharp edge definition and an excellent three-dimensionality". - WHAT Hi-Fi
Will they ever stop this printing this rubbish?
