Go Back   AVForums.com > Other Home Cinema Essentials > Interconnects, Speaker Cables and Switches > HDMI Cables and Switches
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
For Sale : COMPLETE MATRIX TRILOGY gadgetman HD DVD Classified Adverts 7 03-08-2009 7:04 PM
Ditching Sky+HD davo171066 PVRs and VCRs 9 10-07-2009 10:47 AM
For Sale : Blade Runner,Heroes & Ultimate Matrix old stoneface HD DVD Classified Adverts 9 07-07-2009 9:14 PM
Cambridge Audio 640A V2 and Bi-wiring malbon Hi Fi Systems and Separates 13 07-07-2009 12:32 AM
Sky HD channels quieter that SD channels spawn_e_git Sky HD 16 06-07-2009 1:24 PM
Old 05-07-2009, 8:03 PM   #1 (permalink)
Thanks: Gave 25, Got 1
PC video and audio HD output via HDMI matrix to 2 TVs
Hi guys - not sure if this is the right forum but here goes. Currently i watch HD movies via my PC via DVI -> HDMI and SPDIF and also using Sky HD.
What i want to do is output either of the sources to my main TV (which is very close to both the PC & Sky HD box) and my TV in my bedroom (distance approx 12m). My plan is to use a HDMI Matrix Switcher Splitter (4 Input 2 Output) so that i can switch between either source. My problem is that i would prefer to run just one HDMI cable to my bedroom - therefore is there anyway that i can somehow merge the audio & video before it reaches the matrix?
AV Panasonic TX-32LXD80 | KEF KHT 2005.2 | Yamaha RX-V630RDS & DVD S550
PC
QX9650 @ 4.2Ghz | Asus Rampage Formula |
4870 Xfire | Xonar DX | Custom H20
pthomson is offline   Reply With Quote
Old 05-07-2009, 8:38 PM   #2 (permalink)
Assured Advertiser
Jamie S's Avatar
Thanks: Gave 1, Got 90
Re: PC video and audio HD output via HDMI matrix to 2 TVs
Yeap, this is the unit we have for that purpose:
DVI to HDMI with Audio Converter – Free UK Delivery – Shipping Worldwide
Customer Liaison www.HDCable.co.uk
Buy your HDMI Cable from an Official HDMI Adopter. HDMI over IP is here!
Jamie S is offline   Reply With Quote
pthomson (05-07-2009)
Old 05-07-2009, 9:13 PM   #3 (permalink)
Thanks Jamie - do you know if it suports both video + audio via HDMI and SPDIF ---- & video + audio via HDMI only? Thing is, the setup in the living room processes audio via an amp (which doesn't support HDMI) and the TV in my bedroom is just stand alone (no surround sound).
PC
Old 06-07-2009, 7:22 AM   #4 (permalink)
Assured Advertiser
Jamie S's Avatar
Yes it does, you can use both the HDMI and SPDIF output at the same time.
Kind Regards
Jamie
Old 06-07-2009, 10:10 AM   #5 (permalink)
Assured Advertiser
Thanks: Gave 114, Got 886
Hello pthomson
You need to be clear on what you want to achieve
SKY HD will do video + 2.0 LPCM over HDMI + simultaneous DD over Optical - ideal then to 'split the HDMI (Video + 2.0 LPCM) to two or more TV's plus have DD to a local AV Amp.
Your PC will do video over DVI + whatever you manually set it to via SPDIF - you can combine the video and audio signals using a DVI+SPDIF to HDMI converter but you would loose DD from the PC.
If you first split the PC SPDIF so that you can retain a local connection to the AV Amp plus be willing to toggle the PC between 2.0 and 5.1 depending where you want to view/listen then the combiner plus a matrix will work.
Once the PC is set to output 5.1 you wont hear anything on the TV's.
Joe
Joe Fernand is offline   Reply With Quote
Old 06-07-2009, 11:59 AM   #6 (permalink)
Apoligies if i wasn't clear about my end goal.
So i am correct in that i can feed the SkyHD source HDMI into an HDMI matrix splitter and optical to my amp in order to archive simultaneous video & DD sound through my main TV and HD video and mono sound to my bedroom TV (which is not connect to a DD amp)?
Joe
The PC solution appears to be more difficult to sort out. Perhaps it might be easier to use something like a Popcorn hour / WD HDTV for my bedroom setup. That way i won't lose DD from the PC in the lounge.
PC
Old 06-07-2009, 12:32 PM   #7 (permalink)
Assured Advertiser
If its only SKY HD you want to share with multiple rooms you only require a Distribution Amp - Media Factory - Octava HDDA12-UK, 1x2 HDMI distribution amp.
A Networked Media Player may be a far simpler option in each room - you can then view whatever file you want without affecting anyone using the PC; probably best to consider a stand alone NAS drive too!
Joe
Old 06-07-2009, 6:09 PM   #8 (permalink)
Sounds like the right way to go IMO. I think for now i will just focus on Sky HD -> both my TV's and worry about the video streaming later. Thanks for youe help guys
PC
audio, hdmi, matrix, output, tvs, video
