Go Back   AVForums.com > Movies, TV Programmes and Music > On Television > HD TV Programmes
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
stuck pixels vs dead pixels btsam Plasma Televisions 3 09-07-2007 5:59 PM
Dead pixels and DSR mo786 LCD Televisions 2 25-06-2007 7:39 PM
Dead pixels taskam Plasma Televisions 2 10-10-2006 10:43 PM
How many dead pixels do you have? aspender LCD Televisions 79 20-11-2005 10:33 PM
Dead pixels / sticking pixels ? yellowbug Projectors 9 30-04-2004 12:44 PM
Old 01-08-2008, 9:08 PM   #1 (permalink)
Thanks: Gave 419, Got 91
Dead pixels ????
Why is it that on Dexter and Skins (possibly more) that there are dead pixels in exactly the same place on the screen
TeenSpirit is offline   Reply With Quote
Old 01-08-2008, 9:48 PM   #2 (permalink)
Illustrious Member
Starburst's Avatar
Thanks: Gave 157, Got 880
Re: Dead pixels ????
Are you watching a manual recording or perhaps locked recording?
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
Gatecast
Starburst is offline   Reply With Quote
Old 02-08-2008, 8:45 AM   #3 (permalink)
I think we always watch it recorded on our Sky+ HD box - does that make a difference ?
It is really irritating on Dexter at the mo, your eyes just keep focusing on the few dead pixels
Old 02-08-2008, 9:20 AM   #4 (permalink)
Illustrious Member
Starburst's Avatar
Ok, first off if the TV is at fault the dead pixels will there for everything you watch even the TV's own menus.
If this is not the case then there is a well known "bug" in the SKY+HD when creates a very noticeable spot of colour (black) in the same place on the screen when playing back a manual recording or a planner recording that has the Blue Locked function enabled, in other words you have to enter the PIN to watch the programme.
If it's the latter then when it's playing press Pause then the Green button then Backup and you are back in playback and no black dot.
If it's the former then the TV is probably damaged.
Gatecast
TaylorWJ (02-08-2008), TeenSpirit (02-08-2008)
Old 02-08-2008, 3:07 PM   #5 (permalink)
Well I never, thank you - it must be the 'bug' then - I do lock these so daughter can't play them - I will do what you said, thanks again, will let you know how I get on
Old 27-10-2008, 9:24 PM   #6 (permalink)
Thanks for the advice, I turned off the lock and the pixels don't show up now!
glenn_london is offline   Reply With Quote
dead, pixels
