Go Back   AVForums.com > Movies, TV Programmes and Music > On Television > HD TV Programmes
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 27-10-2007, 11:10 AM   #1 (permalink)
Zero_Cold's Avatar
Jean Michel Jarre - Water For Life HD
Hello there..
Is there any chance that someone is able to record Jean Michel Jarre concert from Merzouga in Marocco in HD..I think it's the best concert I saw in my whole life..anybody have equipement to capture HD stream? The gig will be aired:
TPS Star : November, 18th
TF1 : December, 31st
I would kill to get that spectacular concert in HD..
Zero_Cold is offline   Reply With Quote
Old 29-10-2007, 8:07 AM   #2 (permalink)
Zero_Cold's Avatar
Re: Jean Michel Jarre - Water For Life HD
Old 29-10-2007, 3:21 PM   #3 (permalink)
JagoPlasma's Avatar
Thanks: Gave 626, Got 268
instead of killing why not just buy a capture card? depending on which satellite is transmitting it you could prob get all the equipment you need for about £50
GAMERTAG&PSN: WilmaDicfit
Display's:50PZ80, 42PX60 & Optoma HD65 TV Source:Sky HD WD1TB Audio:SCPT560
Consoles:PS3, XBOX360, Wii
Other Stuff:iPhone 16GB, Canon 450D, Sony HDR-SR12E, Linkstation Live 1TB, WD Mybook 1TB
JagoPlasma is offline   Reply With Quote
Old 31-10-2007, 1:47 PM   #4 (permalink)
Zero_Cold's Avatar
Ok..if U think so..
Give me more info about hd tv capture, and a pc (powerful enough) that can support hd sattelite signal and how to unlock french channels TF1 hd or TPS (seca 2) for 50 pounds?
Old 31-10-2007, 1:50 PM   #5 (permalink)
Zero_Cold's Avatar
Thumbs down Re: Jean Michel Jarre - Water For Life HD
Yeah right..
Old 10-12-2007, 10:42 PM   #6 (permalink)
JagoPlasma's Avatar
er no need to be an arse about it, was just helping out. maybe someone more greatful will find this information useful
buy a DVB-S or DVB-S2 capture card depending on which is being used for the channel you want. then hook it upto your pc and use DVBViewer to capture the stream. you may also need some satfinder program/equipment if your dish isnt pointing at the correct satellite.
there simple as that, and can be done on a relatively cheap PC (i recorded the top gear special on a p4 1.5ghz*yes the original p4* with 256mb ram)
as for CAM's and subscription cards, il leave that to you as you're such a smart arse
jarre, jean, life, michel, water
