Advice please re. DTS HD-MA
Old 12-01-2009, 3:26 PM   #1
3,373, Level: 13
Points: 3,373, Level: 13 Points: 3,373, Level: 13 Points: 3,373, Level: 13
Thanks: Gave 4, Got 11
Hi all, I own an EP-10, and after much mucking around with it and my new amp Yamaha AX763, I've realised that the unit will only pass through DTS Core, which I believe means a maximum of 5.1. As I've just bought the German T2 disc, which boasts a 7.1 output, which player do I need (or players, if I have a choice), to allow me to listen to this soundtrack in all its glory? I've searched on Google etc, but can't find anywhere offering a comprehensive overview of the technical specs for the various models. Thanks for your time, any helpmuch appreciated.
Old 12-01-2009, 3:36 PM   #2
2,349, Level: 11
Points: 2,349, Level: 11 Points: 2,349, Level: 11 Points: 2,349, Level: 11
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Thanks: Gave 17, Got 44
Re: Advice please re. DTS HD-MA
XE-1 manual :
http://www.toshibahddvd.co.uk/media/...(061206)_E.pdf
EP-10 manual :
http://www.toshibahddvd.co.uk/media/Media/HDEP10_UK.pdf
EP-35 manual :
http://tesc.toshiba.co.uk/Web/ModelL...EP35KE_Eng.pdf
Old 12-01-2009, 4:10 PM   #3
3,373, Level: 13
Thanks for the reply. However, I already own an EP-10 which unfortunately only outputs to 5.1. Is the EP-30 an option? Not rated the best model, I know, but possibly available cheaply?
Old 12-01-2009, 4:20 PM   #4
awink1's Avatar
6,258, Level: 18
Points: 6,258, Level: 18 Points: 6,258, Level: 18 Points: 6,258, Level: 18
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 176, Got 210
No mate,
XE1 & EP35 are the only ones that can bitstream HD Audio and 7.1
Old 12-01-2009, 4:34 PM   #5
2,349, Level: 11
Activity: 1.2%
Originally Posted by awink1 View Post
No mate,
Yup , absolutely correct ( which is why I gave him the links to those 2 models as well as the manual to his own )
Only other models are the E1 ( too old , doesn't even play at 1080p ) and EP-30 ( which is only renowned for its ability to freeze during playback of HD-DVD discs )
Old 12-01-2009, 6:53 PM   #6
Illustrious Member
48,563, Level: 53
Points: 48,563, Level: 53 Points: 48,563, Level: 53 Points: 48,563, Level: 53
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 884, Got 1,284
and you need a 7.1 receiver to do the decoding whilst you bitstream from a 35 or XE1
Old 12-01-2009, 8:30 PM   #7
2,349, Level: 11
Activity: 1.2%
and presumably a 7.1 speaker system to get the full benefit
Old 12-01-2009, 11:09 PM   #8
3,373, Level: 13
Hi, thanks again. Yes, I've got a 7.1 receiver, and a full 7.1 sound system (comprised of wharfedale pacific evo 30's fronts and rears, pacific evo centre, and pacific evo back surrounds, plus mordaunt-short subwoofer), so it looks like an XE1 or EP35 then. Thanks for the advice.
