AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD Players (High Definition) > HD DVD Players
LinkBack Thread Tools Display Modes
Old 24-11-2007, 11:09 PM   #1 (permalink)
Thanks: Gave 2, Got 4
IS HD DVD stil region free
I am getting the 360 HDDVD drive, and I was wondering if discs purchased in the US will work on the drive?
TV: Toshiba 37C3030D; Virgin Media TV:XL (soon to be V+), BB:XL
DVD: Panasonic DMP-BD10 (Blu Ray) and 360 HD-DVD PLayer (HD-DVD); AMP: Denon AVR1507; PC running Vista Home Premium
Consoles: XBOX 360 Premium (Component) + retro ones
Darthtater is offline
Old 24-11-2007, 11:19 PM   #2 (permalink)
Greg's Avatar
Thanks: Gave 64, Got 330
Re: IS HD DVD stil region free
Yes, they will.
All HD DVDs are region free and will work on any HD DVD player including the Xbox 360 drive.
Only thing you have to remember that the 360 drive and the players are region locked on standard DVDs.
So if you buy a combo HD DVD from the US, then the SD side (which may have the extras on it) will not work on your player.
But to confirm you can buy HD DVDs from anywhere and they will work on your player.
My opinions expressed here are not necessarily those of the AV Forums or the associated websites.
If you are caught on a golf course during a storm and are afraid of lightning, hold up a 1-iron. Not even God can hit a 1-iron.
Greg is offline
Old 25-11-2007, 1:51 AM   #3 (permalink)
Thanks: Gave 37, Got 86
To be technically accurate it's not the 360 HD DVD add-on drive but the 360 console that's locked to a specific SD region (region will be from where you bought the console) forcing playback of SD DVDs of only that region.
AES256 is offline
Old 25-11-2007, 7:22 AM   #4 (permalink)
Jeff's Avatar
Thanks: Gave 54, Got 195
I'm not sure that is correct, normally drives have to be regional coded as well but they are given a grace period (5 plays) before the region is permanently set.
The opinions expressed herein are not necessarily those of AV Forums, not necessarily mine, and probably not necessary.
Jeff is offline
Old 25-11-2007, 12:37 PM   #5 (permalink)
The MS insiders on AVS say that you can buy an add-on drive anywhere in the world, bring it back and use it with your locally-bought 360.
I'd have to look up their exact wording again but I got the impression that the drive didn't lock itself to the region of the 5th SD disc inserted in it, but remained region free i.e. you could then for instance take it to another region and play SD DVDs on a 360 locked to this other region.
All a moot technical point wrt to the 360 because you, of course, need a 360 to play SD DVDs in the first place, and the 360 contains a DVD drive itself (so why use the add-on?).
Interestingly you can use the 360 add-on with your computer. Now there is an advantage to the drive remaining all regions (instead of having to firmware hack it).
AES256 is offline
Old 25-11-2007, 4:27 PM   #6 (permalink)
DeadKenny's Avatar
Thanks: Gave 13, Got 17
Is it confirmed that DVD 'extras' sides on an HD DVD are region coded for the DVD part?
I'm less concerned about not being about to play my SD DVDs but if an HD DVD has the extras in DVD format that could be quite an issue.
Samsung LE40F71BX 1080p | Yamaha DSPAX757SE | Mission Cinema pack (2x 700, 70c1, 2x 70) | Toshiba HD-EP35 region free | UK Series 1 TiVo | Pace Sky Digital | Squeezebox | Wii | PS2
Some former kit: Sony DVP-S325 | Sony KV28FX20 | Sony KV32FQ75 | Sony STR-DB940
DeadKenny is offline
Old 25-11-2007, 4:35 PM   #7 (permalink)
Thanks: Gave 0, Got 17
Basically if it's on a DVD layer it's region coded, if it's on a HD DVD layer it's not. Can't say I can think of any titles which haven't replicated the Extras on the HD DVD layer though (not that I have so many titles either!)... Somewhat irrelevant though as combo discs aren't the norm.
Sony Bravia KDL-40V2000 | Denon AVR-1908 | Denon DVD-2930 | SkyHD | Xbox 360 | Playstation 3 | Wii |
TSThomas is offline
Old 25-11-2007, 4:41 PM   #8 (permalink)
TommyVecetti's Avatar
Thanks: Gave 59, Got 83
I was thinking that because the 5 disc Blade Runner set has the extras in SD. I don't know if this means they will be on DVDs (that are region coded) or on actual HD-DVD discs uncoded.
TommyVecetti is offline
Old 08-04-2008, 8:58 PM   #9 (permalink)
Thanks: Gave 1, Got 0
Question Re: IS HD DVD stil region free
Hey,
Hope this thread is still active but just came across something quite wierd. I don't think play.com has got it right here but anyway
http://www.play.com/DVD/Region_1/4-/...a/Product.html
The first bullet point states "This is an HD-DVD made for HD-DVD Format players which produce higher quality picture and sound. It will only play on North American HD-DVD players"
Now; I can't quite believe that, I'm guessing that play.com has just screwed up, I just wanted to clarify (And it's in the DVD section when it should be in the HD-DVD section :P)
asb3stos is offline
Old 08-04-2008, 9:23 PM   #10 (permalink)
Greg's Avatar
Originally Posted by asb3stos View Post
Hey,
HD-DVD has, and will always be, region free. Just ignore any comments like this on websites.
Greg is offline
asb3stos (08-04-2008)
Old 08-04-2008, 9:24 PM   #11 (permalink)
kingfats's Avatar
Thanks: Gave 911, Got 4,959
H
[/b]Now; I can't quite believe that, I'm guessing that play.com has just screwed up, I just wanted to clarify (And it's in the DVD section when it should be in the HD-DVD section :P)
Hi asb3stos and welcome to the forum.
Don't worry about it HD DVD is region free ..............end of!
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS SB12+, PS3, Oppo 983, S5000ES , XE1, Logitech 1000 remote, wildlife pond in back garden.
Be a man.........make a compost heap!
kingfats is offline
Old 08-04-2008, 9:45 PM   #12 (permalink)
Thanks: Gave 1, Got 15
If i had a disc with extras in dvd format but on a hddvd disc could i get drive to ignore the region via region free software..i have this on my pc and it works great for all dvd regions.
I don't think i have any hddvd's like this although i have a few region 1 and 2 [oz discs]. I could mybe try a little experinment.. i am about to pick up a hddvd drive for pc as a backup to my region 1 player,if i find a region 1 disc with extras in standard dvd format i will try it.
What do you think..
"Ive seen monkeys **** fights in the zoo more organized than this"!
martian1 is offline
Old 08-04-2008, 9:48 PM   #13 (permalink)
Thanks for the reassurance loving the look of this forum, very busy!
asb3stos is offline
dvd, free, region, stil
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wanted : Blu-Rays Region B/Region Free (UK PS3) andyjsg78 Archive : Completed Business and Expired Threads 5 03-11-2007 11:40 AM
Wanted : Terminator 3 region free or region b blu-ray tricky1974 Archive : Completed Business and Expired Threads 3 17-09-2007 4:40 PM
For Sale : The Fountain Blu Ray region A (region free) kourosh Archive : Completed Business and Expired Threads 5 13-08-2007 6:43 PM
Just to clarify HD DVDs are region free but Bluray is only sometimes region free? ensyed HD DVD Players 5 02-07-2007 11:25 AM
Does a multi-region DVDR produce region-free disks? kismet110 DVD Recorders, Recording and Media 11 23-04-2006 5:50 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
