EP30 or EP35 Which to get?
Old 17-10-2009, 11:38 PM   #1
4,489, Level: 15
Points: 4,489, Level: 15 Points: 4,489, Level: 15 Points: 4,489, Level: 15
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 0, Got 20
I am looking to buy a dedicated player to replace my xbox drive. I read the EP35 was the one to get, to go with my new amp an onlyo, for the bitstream audio. However, it seems to be getting more difficult to get hold of an EP35, but theres lots of EP30's around.
Would I really notice the difference between them?
Cheers.
Old 18-10-2009, 9:42 PM   #2
8,205, Level: 21
Points: 8,205, Level: 21 Points: 8,205, Level: 21 Points: 8,205, Level: 21
Thanks: Gave 405, Got 188
Re: EP30 or EP35 Which to get?
Probably not,or very little difference imo.I have both but at this stage of the game the reason to get a player is to be able to play the excellent HD discs for silly money.Buy the EP30 with confidence.
Old 19-10-2009, 1:03 PM   #3
mckee74's Avatar
6,622, Level: 19
Points: 6,622, Level: 19 Points: 6,622, Level: 19 Points: 6,622, Level: 19
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 211, Got 286
Although I would still like an EP-35 for the bitstreaming, I would say with all honesty that I love my EP-30 and you really can't go wrong with it. A superb piece of kit.
Besides, didn't the dirty EP-30 to EP-35 firmware allow you to bitstream Dolby anyway or did I imagine that? Can't remember now.
Old 19-10-2009, 1:11 PM   #4
Marc's Avatar
20,124, Level: 34
Points: 20,124, Level: 34 Points: 20,124, Level: 34 Points: 20,124, Level: 34
Activity: 16.3%
Activity: 16.3% Activity: 16.3% Activity: 16.3%
Thanks: Gave 329, Got 828
Cheers.
the EP30 doesn't support Dolby TrueHD or DTS Master Audio, i would go for the EP35 if you can find one. I upgraded and don't regret it
Old 29-10-2009, 6:55 AM   #5
Banksie's Avatar
2,556, Level: 11
Points: 2,556, Level: 11 Points: 2,556, Level: 11 Points: 2,556, Level: 11
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 21, Got 22
THe EP30 does support Dolby tru HD it decodes onboard and sends it out as PCM. and with Viking61's (top man) dirty hack you can multi region it and get it to bitstream Dolby Digital+.
Old 29-10-2009, 4:58 PM   #6
4,489, Level: 15
Activity: 2.0%
I managed to get a 35 from here, works great in true hd.
Cheers.
