disk not working
Old 24-09-2009, 9:12 AM   #1
927, Level: 6
Points: 927, Level: 6 Points: 927, Level: 6 Points: 927, Level: 6
Thanks: Gave 15, Got 5
disk not working
hi there, i have an EP-30 i got off these forums and worked great, iv updated to version 4.0 firmware.
i got a qeen live in montreal hd dvd dsk off these forums and it will not play. It doesnt look scratched if tried cleaning (although not a professional job or anything)
the player trys to load it but after what seems like ages it says disk not in dvd format.
is there anything i need to do? all my other hd dvd work
any thoughts would be appriciated
Old 24-09-2009, 4:04 PM   #2
a4lloxo's Avatar
4,216, Level: 15
Points: 4,216, Level: 15 Points: 4,216, Level: 15 Points: 4,216, Level: 15
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 100, Got 66
Re: disk not working
try clearing the persistent storage,found under the maintenence section in the players setup menu,then initialise the player,also found in the same section of the setup menu
