Firmware upgrade question
Old 10-09-2009, 10:02 AM   #1
3,494, Level: 13
Points: 3,494, Level: 13 Points: 3,494, Level: 13 Points: 3,494, Level: 13
Thanks: Gave 0, Got 21
I have a question guys.
My E35 was updated from 1.3 to version 2.
Then when going to update procedure again a newer version was found
4.0/2.0
and the HDDVD asks if I want to proceed with the update.
When I press yes a few seconds later a message appears saying that the software has been updated and the updated procedure will be terminated.
However as many times as I go to the update procedure the same picture appears 4.0/2.0 as if the E35 need to be updated.
What is wrong here?
Nick
Old 10-09-2009, 10:08 AM   #2
1,741, Level: 9
Points: 1,741, Level: 9 Points: 1,741, Level: 9 Points: 1,741, Level: 9
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 4, Got 8
Re: Firmware upgrade question
Nothing wrong. That is what it should say.
Old 10-09-2009, 10:11 AM   #3
3,494, Level: 13
Thanks but as I see it it is as I have the 2.0 version and need to upgrade to 4.0
What am I missing here?
Nick
Thank you in advance
Old 10-09-2009, 11:28 AM   #4
mjcairney's Avatar
13,039, Level: 27
Points: 13,039, Level: 27 Points: 13,039, Level: 27 Points: 13,039, Level: 27
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 195, Got 526
Nick
Hi there,
You are not missing anything - that's just the (slightly confusing) way they do it. You are on version 4.0
Cheers,
Martin.
Old 10-09-2009, 12:05 PM   #5
3,494, Level: 13
Originally Posted by mjcairney View Post
Hi there,
Cheers,
Martin.
Thank you very much Martin,
That is a relief!
Cheers,
Nick
Old 10-09-2009, 12:17 PM   #6
mjcairney's Avatar
13,039, Level: 27
Activity: 6.8%
That is a relief!
Cheers,
Nick
My pleasure.
Cheers,
Martin.
