Best HD-DVD player
Old 08-09-2009, 7:28 PM   #1
Spy Spy is offline
Spy's Avatar
9,312, Level: 23
Points: 9,312, Level: 23 Points: 9,312, Level: 23 Points: 9,312, Level: 23
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 87, Got 199
Best HD-DVD player
Hi all,
I was wondering which is meant to be the best HD-DVD player (US or EU) that can:
- output 1080p
- internal decoding of all HD audio formats and output as PCM through HDMI
Also, how do the US/EU players inter-relate with each other ?
For example, is an XA2 the equivalent of the XE1 ?
Old 08-09-2009, 7:31 PM   #2
5,403, Level: 17
Points: 5,403, Level: 17 Points: 5,403, Level: 17 Points: 5,403, Level: 17
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 330, Got 149
Re: Best HD-DVD player
Originally Posted by Spy View Post
Hi all,
- output 1080p
XA2 IS the equivalent of XE1 and these, I believe, are the top models for HD DVD players.
Old 08-09-2009, 7:51 PM   #3
Spy Spy is offline
Spy's Avatar
9,312, Level: 23
Activity: 2.3%
Thanks, I thought so but wanted to check.
Can you confirm if it has on-board HD-audio decoding that can be outputs as PCM via HDMI ?
Old 08-09-2009, 8:15 PM   #4
5,403, Level: 17
Activity: 0.8%
Yes for XE1, almost definite for XA2!
Old 10-09-2009, 9:39 AM   #5
1,741, Level: 9
Points: 1,741, Level: 9 Points: 1,741, Level: 9 Points: 1,741, Level: 9
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 4, Got 8
Smile Re: Best HD-DVD player
Don't forget the Onkyo DV-HD805.
Old 11-09-2009, 6:53 PM   #6
Dutch's Avatar
8,434, Level: 21
Points: 8,434, Level: 21 Points: 8,434, Level: 21 Points: 8,434, Level: 21
Thanks: Gave 233, Got 115
Only for Dolby TrueHD, not DTS-HD which is bitstream only.
Steve
Spy (11-09-2009)
