ep 30 - very strange fault, ideas?
Old 13-07-2009, 7:58 PM   #1
7,683, Level: 20
Points: 7,683, Level: 20 Points: 7,683, Level: 20 Points: 7,683, Level: 20
Thanks: Gave 55, Got 82
have a strange fault, the disc tray keeps opening and closing, a couple of times then stays open. With or without a disc it does this. I manual push 'close' it closes then opens again and stays open. Basically not enabling the 'loading' function to work. If I switch it to standby, it leaves the tray open and I have to phisically push it closed. I have tried going into 'maintanence' and done 'initialize'. Any ideas?
cheers
Old 13-07-2009, 8:28 PM   #2
Eminent Member
kingfats's Avatar
106,213, Level: 79
Points: 106,213, Level: 79 Points: 106,213, Level: 79 Points: 106,213, Level: 79
Thanks: Gave 1,193, Got 7,647
Re: ep 30 - very strange fault, ideas?
Originally Posted by simonoaks View Post
cheers
Does sound like a faulty player i'm afraid was a poster with similar problem (yonks ago now) but the machine had to be sent in for repair.
Not much help i know,sorry about that.
All the best.
Old 13-07-2009, 8:51 PM   #3
Viking61's Avatar
8,892, Level: 22
Points: 8,892, Level: 22 Points: 8,892, Level: 22 Points: 8,892, Level: 22
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 29, Got 636
I would have taken out the drive and opened it. See if there is some small piece stuck in there making the tray not close properly. In that case it would open again automatically.
Old 13-07-2009, 9:38 PM   #4
7,683, Level: 20
thanks, bought on here a while back for 70 quid, so no big deal, although I bought 20 film and only watched 3 lol.
does no harm to take a look, if I can fix it, then I will just have to go back to the 'for sale' and get another one
