Toshiba HD-XE1 audio output help
Old 22-06-2009, 5:38 PM   #1
7,003, Level: 19
Points: 7,003, Level: 19 Points: 7,003, Level: 19 Points: 7,003, Level: 19
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 29, Got 20
I have the above connected by coax to my amp, would i get better sound through using the 6 analogue outputs and selecting multi in,my sony amp (str-da1200es ) doesn't do audio over hdmi
Robert
Old 22-06-2009, 7:02 PM   #2
4,762, Level: 16
Points: 4,762, Level: 16 Points: 4,762, Level: 16 Points: 4,762, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 44, Got 56
Re: Toshiba HD-XE1 audio output help
Originally Posted by RobTi View Post
I have the above connected by coax to my amp, would i get better sound through using the 6 analogue outputs and selecting multi in,my sony amp doesn't do audio over hdmi
Robert
You haven't told us what Sony amp you have, but given it doesn't take audio over HDMI it may well be better to use the analogue inputs and get the XE1 to do the work. My Meridian processor doesn't take HDMI, but it will do DTS better than the XE1, but not True HD.
dpstjp
Old 23-06-2009, 8:49 AM   #3
a4lloxo's Avatar
4,216, Level: 15
Points: 4,216, Level: 15 Points: 4,216, Level: 15 Points: 4,216, Level: 15
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 100, Got 66
using analogue out you will get LPCM which is the same as TrueHD
RobTi (23-06-2009)
Old 23-06-2009, 9:05 PM   #4
7,003, Level: 19
Activity: 2.7%
thanks
Robert
