Toshiba HD-XA1 - Can it be made multi region?
Old 19-05-2009, 1:54 PM   #1
2,420, Level: 11
Points: 2,420, Level: 11 Points: 2,420, Level: 11 Points: 2,420, Level: 11
Thanks: Gave 11, Got 17
Hi folks,
Is this a player that can be made multi region for SD DVD? And is it easy?
Thanks.
Also, I understand it's ony 1080i, but is it a good player, generally?
Thanks,
James
Old 19-05-2009, 3:43 PM   #2
Dutch's Avatar
8,434, Level: 21
Points: 8,434, Level: 21 Points: 8,434, Level: 21 Points: 8,434, Level: 21
Thanks: Gave 233, Got 115
Re: Toshiba HD-XA1 - Can it be made multi region?
Unfortunately, the XA1 will not even play a region-free PAL DVD, so multi-region capability is fairly remote. Yes, it will only output 1080i60, but with the right TV, e.g. Pioneer Kuro, a super 1080p72 picture can be produced. And of course, it's built like the proverbial brick outhouse.
Steve
Old 19-05-2009, 10:21 PM   #3
a4lloxo's Avatar
4,216, Level: 15
Points: 4,216, Level: 15 Points: 4,216, Level: 15 Points: 4,216, Level: 15
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 100, Got 66
Originally Posted by jamesking View Post
Hi folks,
Thanks.
Thanks,
James
if youve got a chance of one at reasonable money snap it up,they are quality players
Old 08-09-2009, 7:44 PM   #4
Spy Spy is offline
Spy's Avatar
9,312, Level: 23
Points: 9,312, Level: 23 Points: 9,312, Level: 23 Points: 9,312, Level: 23
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 87, Got 199
Steve
How does the 1080p72 work then ?
Old 11-09-2009, 6:39 PM   #5
Dutch's Avatar
8,434, Level: 21
The Kuro will convert the 1080i 60Hz signal (60 fields) to obtain the original 24 1080p frames per second. The 24 frames are then shown three times each when the Kuro is set to PureCinema Advance mode.
Steve
Spy (11-09-2009)
