Toshiba HD-EP30 3rd Generation 1080/24 HD DVD Player Review
Old 22-07-2008, 4:30 PM   #1
News Supplying Robot
206,601, Level: 100
Points: 206,601, Level: 100 Points: 206,601, Level: 100 Points: 206,601, Level: 100
Activity: 99.0%
Activity: 99.0% Activity: 99.0% Activity: 99.0%
Thanks: Gave 0, Got 273
Reviewed by Phil Hinton
Sadly the EP30 misses out on the recommended badge award as it doesn’t do everything as perfectly as it should. However if you are after just a cheap and cheerful HD performer and can get around the video processing issues by using a quality display, then your money does go a long way, especially with those free movies thrown into the mix. Sadly the EP30 is in our minds a missed opportunity at this point for all round greatness, but if you are prepared for cheap build quality and good HD playback, mixed with a few issues that may or may not be fixed by firmware and your using a quality display, you probably cannot argue with the sub £200 price point. Cheap HD is here, just not quite as perfect as it could be, but the fact is, it may still get better!
Read the full review...
HTML code is On
