As I'm on holiday, I've watched 5 blu-rays in the last day and not seen a single glitch on my le40c650. I turned off the 24hz output and sent 1080/60 instead.
1) Maybe this is related to the frame-rate problem the engineer on SAMYGO was talking about. Maybe the motion plus system is not switching off-on because of the increased frame-rate.
2) I was expecting telecine judder because of 3:2 cadence. This is true except in Custom, where it looks identical to the 24hz output, even at (0, 0). I have been using (10, 0) and (10, 2) and it has been fine.
3) I'm not saying it won't stutter, but I would expect to see at least 25/30 incidents over the course of 5 films with 24hz engaged.
4) I don't think it is the 24hz output of the ps3 that is at fault. I have used it on other peoples tvs (Sony/Panasonic) and never had a frame -skipping problem at 24 hz.
I just thought this might be useful whilst we await a fix from Samsung. Clearly, results may vary due different models/firmware, but it might be worth a shot.
I wonder if anybody could explain to me what Custom could be doing to at 60hz, 3:2 input to give a smooth output, even at (0, 0).
I'm no expert, and only joined this forum to get help when manufacturers didn't know what I was talking about!
So many thanks for listening.
