Originally Posted by Pecker Phil, thanks for that excellent review.
A couple of questions for you.:
1 - What would you say are the pros and cons of this vs the 750? Which would you buy, and why?
2 - Improved zoom is nice. Is that zoom flexible enough to use it as a 'CIH-without-anamorphic' projector? If so, how far away from a 3m wide ('scope) screen would it need to be placed?
Cheers.
Steve W |
Our reference machine is the HD750 so I think that says everything. (Black levels, and reference colour performance). The Optoma is good, but not in the same class (or price point). Will be more interesting to see the HD86 which is in the same price level as the HD750 and more of a competitor (it has a cms/white balance and gamma controls).
You will have to work the second one out yourself as the sample has gone back. Remember you would need to zoom manually and focus each time you moved in most circumstances. If that's the approach you want to take I would recommend the PT-AE3000 which has memory settings for this approach with focus and zoom.
