64 gb usb drive help
Old 14-07-2012, 3:43 PM   #1
jimbobarooney's Avatar
Thanks: Gave 44, Got 42
hi all ive just got a 64gb usb drive, and it beeps when i put it in my pc, but it wont show up, and when i go into my computer, manage, disc management,
the disc shows up but it wont let me put anything on it,
it appears as disc 1 not initialized, and unknown, with a red arrow pointing down, and as such it wont let me do anything with the blody thing, any ideas?? ive tried it in 2 laptops and the pc with the same outcome,
thanks in advance jim
Old 14-07-2012, 3:50 PM   #2
Eminent Member
Badger0-0's Avatar
Thanks: Gave 512, Got 2,011
Sounds like it needs formatting/partitioning to me.
You should be able to do that in disc management.
Old 14-07-2012, 5:05 PM   #3
Trollslayer's Avatar
Thanks: Gave 764, Got 955
In disk manager, initialise it first then format.
Old 14-07-2012, 5:06 PM   #4
Thanks: Gave 138, Got 50
Badgers right, you should be able to right click in the disk management but and initialise and format it at the same time..
Old 14-07-2012, 5:07 PM   #5
Sorry trollslayer typed at the same time..
Old 14-07-2012, 5:37 PM   #6
on the mbr in the manager bit it says the drive is write protected!
Old 14-07-2012, 5:42 PM   #7
Great minds etc..
blowy111 (14-07-2012)
Old 14-07-2012, 5:45 PM   #8
and if i right click the card, it has got the initialize disc option is greyed out,
Old 14-07-2012, 7:35 PM   #9
Is there a lock (ie write protect) switch on the stick..?
Maybe this is in the lock position.
Old 14-07-2012, 7:51 PM   #10
nope nothing on it,
Old 17-07-2012, 5:52 PM   #11
Spudhead's Avatar
Thanks: Gave 75, Got 55
Where did you buy it from? Email them and say you want a refund of some sort as it appears to be faulty or help on how to get it working?
Old 22-08-2012, 10:19 AM   #12
Sorted, It was a dodgy drive, emailed company, and they sent out an replacement,
