SSD Cache Drive + SATA 1 HDD
Old 31-05-2012, 6:51 PM   #1
Bemused One's Avatar
Thanks: Gave 17, Got 14
Hello everyone.
I need to pick the brains of some of you learned folks again.
I was thinking of adding an SSD cache drive to my parents computer to try and make it a bit snappier. However the hard drive in said computer is only SATA 1 and it's running in IDE mode in the BIOS. What I would like to know is would I have to enable AHCI mode in the BIOS for the SSD cache drive and would a performance increase be gained when it's paired with a SATA 1 HDD?
I'd appreciate any help with this.
Thanks.
Old 31-05-2012, 11:38 PM   #2
maf1970's Avatar
Thanks: Gave 10, Got 244
Given that SSD cache drives are SATA III I doubt you would see the improvement you think it would make. Cache drives are aimed at setups that have large capacity sata II or III drives.
I would suggest that you find out more about the spec of your parents machine overall and come back with that then we will be able to help you better.
Old 01-06-2012, 4:33 AM   #3
Thanks: Gave 39, Got 80
On an old computer, using windows, XP doesnt really know SSD's exist, Vista is slightly better but you really need Windows seven to use any SSD properly, and even more so for a cache drive. Linux, I presume, is better at SSD's ?
Old 01-06-2012, 5:11 PM   #4
There are SATA 2 SSD cache drives available for purchase such as the Corsair Accelerator series. I was hoping one of them would do the job? Obviously I know I'd only get SATA 1 speeds from it, but what I'm trying to find out is if that would be an improvement over the standard HDD?
Spec is as follows:-
Intel Core i3 530 CPU
Gigabyte H55M-UD2H Motherboard
4GB Corsair XMS3 DDR3 RAM
Samsung SP0812C 80GB HDD
400W Antec PSU
Windows 7 64bit
Do you need any more details?
Old 01-06-2012, 8:32 PM   #5
maf1970's Avatar
Thanks for the info. Straight away the first thing that springs to mind is what is a SATA 1 drive doing in a setup like that ? I was expecting you to post a more antiquated system in need of help.
Why not just replace the drive with something like -
Western Digital RE4 250GB SATA-II 64MB Cache - OEM (WD2503ABYX) [WD2503ABYX]
or buy a second hand SATA II SSD.
Also make sure motherboard BIOS is up to date.
Old 02-06-2012, 1:55 AM   #6
Dont get hung up about sata1 etc, the ability of a SSD to speed up a machine is more on its access speed, which is about 40x - 100x faster than a Hard disk. Re installing the OS on the PC and keeping it free of crud, can do much to speed up machines, along with more memory and I reckon you would be better off just straight replacing the 80gb disk with a 128gb SSD. Can be bought for less than £100 and will make your parents gasp! when using it.
In fact if you install a SSD it is wise to reinstall the OS anyway to get best use out of it
Old 03-06-2012, 7:29 PM   #7
Straight away the first thing that springs to mind is what is a SATA 1 drive doing in a setup like that? I was expecting you to post a more antiquated system in need of help.
The computer my parents currently have is something I threw together for them the other week using parts from my older rigs. I knew the hard drive was the weakest part in the machine, but based on my parents usage (mainly internet and e-mail) I thought it was sufficient for them.
Why not just replace the drive with something like - Western Digital RE4 250GB SATA-II 64MB Cache - OEM (WD2503ABYX) [WD2503ABYX] or buy a second hand SATA II SSD.
I thought an SSD cache drive would be the best option in terms of both cost and performance. Had the HDD in my parents machine been SATA 2 I wouldn't have hesitated, but as it's not I thought I'd ask for advice here first.
Um...why is this necessary?
So there would be a performance increase even on a SATA 1 HDD if it was paired with an SSD cache drive?
...I reckon you would be better off just straight replacing the 80gb disk with a 128gb SSD. Can be bought for less than £100...
Yes that would be ideal, but it's just too pricey an option I'm afraid.
Old 09-06-2012, 2:18 PM   #8
Thanks: Gave 200, Got 323
Why not just buy a Sata 3 hard drive
The costs have come down considerably and you'll notice the difference
How much is a SSD cache drive going to cost?
120gb SSDs are going for £80, and some even cheaper
Old 09-06-2012, 7:06 PM   #9
This may be a silly question, but I'm going to ask it anyway. Would a Sata 3 HDD running at Sata 2 speeds outperform an SSD cache drive running at Sata 1 speeds?
The one I was considering was £43.99 and was Sata 2. Obviously it could only run at Sata 1 speeds because of the Sata 1 HDD, but what I've been trying to find out is if such a pairing would be worth it or pointless. I get the impression it's the latter.
Old 10-06-2012, 12:10 PM   #10
Probably not much point
I imagine the old HDD is quite a few years old
For £43 you could get a new Sata 3 drive (I imagine that boards supports sata 3) and I think you will see quite a speed difference with load times
Old 10-06-2012, 8:34 PM   #11
Oh well, at least I know now.
It is yes. If I remember correctly, circa 2005.
I'm afraid not. It only goes up to Sata 2.
Would you still recommend a Sata 3 HDD given it would only be running at Sata 2 speeds?
Old 10-06-2012, 9:26 PM   #12
I'd still go for sata 3 anyway. Just because the price difference is minimal (if none)
Old 11-06-2012, 5:49 PM   #13
Many thanks for your advice Delvey.
I've acquired a Sata 3 drive for my parents computer now, only it's not an HDD. I was able to grab a 64Gb Samsung 830 SSD drive for a really good price. It was little more than what the SSD cache drive I was considering cost, so I was really chuffed about that. I'm looking forward to installing it in my parents machine. I'll finally be able to see for myself what all this SSD fuss is about.
Old 11-06-2012, 5:54 PM   #14
You'll be taking it home for yourself.
Id keep the old hard drive for media (music, pictures)
Check the guide in this section for moving the documents to an alternate drive, saving the valuable SSD space
You will be surprised at windows loading speeds
Old 12-06-2012, 5:12 PM   #15
LOL! I'll try not to.
Other than various types of documents and a few pictures, my parents don't really have much else stored on their computer. Would I even need the old HDD for them? Can't they just be stored on the SSD?
Yeah it's a great guide. I'll definitely be making use of it.
I'm really looking forward to seeing this for myself.
Old 12-06-2012, 6:02 PM   #16
Probably will not need the other HDD if there not storing much on the SSD
One thing I would do is upgrade the firmware
I did, and the system rating went from 6.9 to 7.4
I am using a sata 3 SSD in a sata 2 port
Old 13-06-2012, 4:22 PM   #17
Is it safe to install all your hardware drivers and various kinds of software on an SSD?
Thanks for the advice. I'll definitely look into this.
Is everything still fairly snappy then?
Old 13-06-2012, 7:21 PM   #18
Everything seems real snappy
Takes about 10 seconds from pressing the power button to windows being loaded
Installing drivers etc is fine on a ssd
Old 13-06-2012, 7:54 PM   #19
spyder viewer's Avatar
Thanks: Gave 242, Got 567
Why don't you put the old hard drive in an external usb case and use it for back-up? You could even take an image of the ssd for easy system restores.
Old 14-06-2012, 10:22 AM   #20
Thanks: Gave 9, Got 17
Isn't your mobo a SATA2?? Specs from Gigabyte say its SATA 3GB/s (GIGABYTE - Motherboard - Socket 1156 - GA-H55M-UD2H (rev. 1.0))
which is SATA 2 (Serial ATA - Wikipedia, the free encyclopedia)
Old 14-06-2012, 11:04 AM   #21
He already knows that I think
There Sata 2 drives are slightly cheaper, this one is £60 Sandisk 120GB Ultra SSD - Solid State Drive - SDSSDH-120G-G25 - Scan.co.uk but the read and write speeds are not as quick as the sata 3 model
It would still make a huge difference to load times however
Old 14-06-2012, 11:12 AM   #22
As he has already gone out and bought an SSD, my info isn't much use.
It would be nice to find out if it has solved his original problem though?
Early on in the thread he thought he had a SATA1 mobo and was worried about using a SATA2 drive on it. I just wanted to make sure that he knew that his mobo was SATA2 for future reference
Old 17-06-2012, 4:44 PM   #23
Umm...is doing this after installing Windows 7 on to the SSD drive safe?
Sounds good. Definitely an improvement over nearly 2 minutes.
Thanks for that.
That's something that never occurred to me. Thanks for the idea.
How do you go about doing that exactly?
It certainly is.
I certainly do, yes.
No, no, this is incorrect. I've always known the motherboard was Sata 2. What I was wanting to know was whether or not pairing a Sata 1 HDD with a Sata 2 SSD cache drive on the same motherboard would improve performance i.e. just make things snappier.
Old 19-06-2012, 12:07 PM   #24
You could update the firmware before installing the OS by using an hard drive which has an OS already
Old 21-06-2012, 4:30 PM   #25
Thanks for the advice Delvey, but I did something different. I made a bootable USB, which worked a treat, only for the thing to tell me the firmware on the drive was the latest one available. Always a good thing.
I've got the SSD drive installed in my parents computer now. I installed Windows 7, all hardware drivers and some software on to it yesterday. I can't say I'm very impressed with it however. I mean, sure, Windows loads up and shuts down a bit quicker, but I can't really say I've noticed much difference to performance when in the OS. I'm quite disappointed.
I've got a couple more questions, if anyone could help me out?
Should I have formatted the SSD before installing Windows 7 on to it? I assumed the install disk would have done this had it been necessary, but it just went straight to installing the OS. Is that okay?
Should I turn off indexing on the SSD drive?
Old 22-06-2012, 1:29 PM   #26
Strange that
I didn't format mine before installing windows
I do not have indexing on
Check the BIOS and make sure Sata mode is set to AHCI
If that fails try a different sata port or sata cable
Could always use crystalmark to bench it and post the results here
Old 22-06-2012, 6:45 PM   #27
Hello again Delvey.
Strange that
I thought so. It's made me wonder whether or not I've done something wrong?
That's a relief. At least I didn't screw that bit up then.
Do you know how this is supposed to help the SSD?
Yes, that's set properly. In fact it was the first thing I did when setting up the SSD.
Isn't Sata 0 the best sata port for an SSD?
Does that effect the SSD's life span in any way?
Old 26-06-2012, 12:39 PM   #28
It shouldn't matter which sata port you have it plugged into
I do not think bench marking it will have a massive effect on the life of the SSD, especially if it's just a one off thing
Old 03-07-2012, 5:05 PM   #29
Apologies for taking so long to reply.
I downloaded and ran CrystalDiskMark and here are the results:-
Sequential Read : 261.392 MB/s
Sequential Write : 168.962 MB/s
Random Read 512KB : 200.343 MB/s
Random Write 512KB : 155.177 MB/s
Random Read 4KB (QD=1) : 18.335 MB/s [ 4476.3 IOPS]
Random Write 4KB (QD=1) : 50.370 MB/s [ 12297.5 IOPS]
Random Read 4KB (QD=32) : 195.202 MB/s [ 47656.7 IOPS]
Random Write 4KB (QD=32) : 67.214 MB/s [ 16409.7 IOPS]
Test : 1000 MB [C: 35.2% (20.9/59.5 GB)] (x5)
Sorry, I don't know how to post the above as a graphic. Could anyone please enlighten me about how to do that though as I'd love to know?
So are the above results good? I have no clue what they mean.
Is my parents new SSD working as it should?
