Originally Posted by Voy06 When I started the laptop after installing the new ram I was given 3 options, Save changes, ignore changes and Computer set-up. I chose save changes, is that correct? |
That sounds like some sort of HP or security authentication thing, I don't think it'll have anything to do with the blue screens.
Initial failure rate for many computer components is rather high (one or two per hundred) so it may just be a dud RAM stick. Try the laptop with one ram stick in and then the other and see if either of the new sticks work alone. If one works fine then it's likely to be a fault in the other stick rather than the wrong sort of ram.
