Halo ODST Audio Logs
Old 28-09-2009, 5:59 PM   #1
2,791, Level: 12
Points: 2,791, Level: 12 Points: 2,791, Level: 12 Points: 2,791, Level: 12
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 38, Got 30
Am I right in thinking this is the best way to get them solo
finish campaign
unlock streets and go through getting logs 1-29
replay data hive level
Old 28-09-2009, 8:07 PM   #2
5,507, Level: 17
Points: 5,507, Level: 17 Points: 5,507, Level: 17 Points: 5,507, Level: 17
Thanks: Gave 22, Got 35
Re: Halo ODST Audio Logs
Yep!
Doing it myself tonight.
Man of Kent (28-09-2009)
Old 29-09-2009, 5:41 AM   #3
jamienufc's Avatar
11,983, Level: 26
Points: 11,983, Level: 26 Points: 11,983, Level: 26 Points: 11,983, Level: 26
Thanks: Gave 334, Got 369
The below guide is really useful for getting the audio logs
HALO 3 ODST Hidden Audio File Guide Map
Old 29-09-2009, 9:11 AM   #4
3,734, Level: 14
Points: 3,734, Level: 14 Points: 3,734, Level: 14 Points: 3,734, Level: 14
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 44, Got 22
Best to do them during the campaign as they also unlock weapons caches that are quite handy, means you can keep using your favourite weapon and don't have to rely on inferior alien scum Also a couple have a couple of mongooses in to play with, makes it easier to whip around the map.
Old 29-09-2009, 9:14 AM   #5
Billy Goodgun's Avatar
7,658, Level: 20
Points: 7,658, Level: 20 Points: 7,658, Level: 20 Points: 7,658, Level: 20
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 459, Got 450
You can collect audio logs on your own or in co-op, it doesn't matter. If you have any friends who want them all as well, it'll save you both a lot of time and hassle to do it collectively - just be patient, that's all!
Be warned, though: despite what the campaign menu tells you about saving your VISR data and audio log progress, it still insists on having different details for both your co-op and your solo campaigns. If you have no logs from a previous co-op campaign, you will have to start from scratch, regardless of how many you've collected on your jack jones.
Old 29-09-2009, 10:12 AM   #6
11,164, Level: 25
Points: 11,164, Level: 25 Points: 11,164, Level: 25 Points: 11,164, Level: 25
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 904, Got 568
Just done these this morning.
Took me around 3 hours start to finish.
This is a better guide, its the one I used. Its much quicker when you use the mongooses to get around the city
Halo 3: ODST - Audio Log guide | GamesRadar
chevvy (29-09-2009), Man of Kent (29-09-2009)
Old 30-09-2009, 8:47 AM   #7
Illustrious Member
45,880, Level: 52
Points: 45,880, Level: 52 Points: 45,880, Level: 52 Points: 45,880, Level: 52
Activity: 87.2%
Activity: 87.2% Activity: 87.2% Activity: 87.2%
Thanks: Gave 1,843, Got 3,281
Something odd and kinda cheap i found out yesterday regarding the audio logs
My friends were playing co-op and i came online, they ended it invited me on and carried on from where they left off
They soon picked up an audiolog and i had as many as them (half a dozen or so) despite me only being there to pick up one
I guess it means you could join your friend just before they pick up the 30th and you get the achievement
Old 30-09-2009, 9:03 AM   #8
11,696, Level: 25
Points: 11,696, Level: 25 Points: 11,696, Level: 25 Points: 11,696, Level: 25
Activity: 7.6%
Activity: 7.6% Activity: 7.6% Activity: 7.6%
Thanks: Gave 473, Got 821
Like Fable II? Oh well, at least it's only the one achievement and not every one in the game .
Old 30-09-2009, 9:14 AM   #9
Illustrious Member
45,880, Level: 52
Activity: 87.2%
Be interesting to see if a new player got them all if only joined for the 30th eg the previous ones stacked
but yes, at least Bungie didnt make it "Do x or watch the it happen in theater"
Old 30-09-2009, 5:18 PM   #10
Location: Real guitars don't have strings, they have 5 coloured buttons.
28,493, Level: 41
Points: 28,493, Level: 41 Points: 28,493, Level: 41 Points: 28,493, Level: 41
Activity: 12.9%
Activity: 12.9% Activity: 12.9% Activity: 12.9%
Thanks: Gave 616, Got 940
There is a very good series of videos on the youtube, I've been using them so far I only have the link for this one at the moment
Halo 3 ODST Audio Logs 11-15 "Kizingo Boulevard"
Old 08-10-2009, 8:28 AM   #11
8,122, Level: 21
Points: 8,122, Level: 21 Points: 8,122, Level: 21 Points: 8,122, Level: 21
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 585, Got 93
I finished the game in co-op and missed loads of audio logs. How do I go back and get the missing audio logs (either by myself or in co-op)?
Is there a menu somewhere that lets you go back and to the hub world and play as the rookie?
Old 08-10-2009, 12:01 PM   #12
7,658, Level: 20
Activity: 6.1%
Yes - if you've finished the game, you should have the option to select "Mombasa Streets" and play that. Get all your audio logs that way. There should be a few guides posted around with locations.
You might also want to pick up "Naughty naughty" while you're at it (kill 10 of them thar flying "Virgil" things).
amardilo (08-10-2009)
Old 08-10-2009, 3:45 PM   #13
11,696, Level: 25
Activity: 7.6%
Now I'm not completely sure but I think I read that your co-op audio logs don't apply to single player so if you already have some from co-op you'll have to get the rest in co-op too. You may want to check this with someone else though.
Edit: I probably heard about it in Billy's post (#5) ^^^
Old 08-10-2009, 3:55 PM   #14
Illustrious Member
45,880, Level: 52
Activity: 87.2%
Engineers
Old 21-10-2009, 5:38 PM   #15
909, Level: 6
Points: 909, Level: 6 Points: 909, Level: 6 Points: 909, Level: 6
Thanks: Gave 2, Got 6
Cheers for the maps, have just started to collect these. Am half way through, takes ages to walk all about the city!
Old 21-10-2009, 8:23 PM   #16
6,797, Level: 19
Points: 6,797, Level: 19 Points: 6,797, Level: 19 Points: 6,797, Level: 19
Activity: 1.7%
Thanks: Gave 139, Got 55
Don't worry, you'll get a Mongoose for your troubles soon enough .
Old 26-10-2009, 7:50 AM   #17
909, Level: 6
Am hoping even more so now, worked my way to the top of the map & am 4 logs missing to take me to 29. Doh!
