Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Gaming > Xbox Gaming > Xbox 360 > Xbox 360 Games > Guitar Hero Xbox 360
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Novice requires help and advice with laptop spec! ieatwork Laptops and Netbooks 23 31-01-2009 12:04 AM
media streaming help/advice Dr Asqueroso PS3 Media & Streaming 19 28-01-2009 4:37 PM
Sub £600 5.1 speakers - HELP anth.payne Speakers 14 27-01-2009 6:28 PM
Old 27-01-2009, 12:04 PM   #1 (permalink)
Thanks: Gave 50, Got 19
Help! wireless Les Paul guitar red button not working!
Help please guys N girls ive got a wireless Les Paul guitar and the red button just decides to stop working, Ill be half way through a rift playing along and then the red button will just stop working unless you bash it really hard (and that cant be right), and then it sometimes sticks in place.
Any ideas whats up with it, all the other buttons work fine.
I can only think i might need to clean it. Do i need to clean it and if i do how do you clean it as it appears to be a sealed unit?
ajwatson is offline   Reply With Quote
Old 27-01-2009, 1:35 PM   #2 (permalink)
Thanks: Gave 238, Got 399
Re: Help! wireless Les Paul guitar red button not working!
I wonder if your problem is similar to this...?
Faulty Les Paul
FWIW, the fret board part can be opened using a T10 screwdriver if you think the inside of it needs a clean.
PlexShaw is offline   Reply With Quote
ajwatson (27-01-2009)
Old 27-01-2009, 6:51 PM   #3 (permalink)
Ok well ive read that other thred and its similar to me however ive not got the privlige of being able to take mine back to the shop!
So ive looked at the bak of the guitar and there not screwed with normal screws they look like star heads whats that all about?
How do you actually clean it when uve got it open?
Old 27-01-2009, 8:43 PM   #4 (permalink)
I'm guessing you read this already, but as I said in the other thread, check the connectors on the circuit board at the base of the fret board. If they're covered in black dots you might be able to clean them off with a dry cotton bud. That is more than likely to be the cause of the trouble, rather than the fret button itself being damaged (although you may have messed it up by pressing it too hard).
As for the screwdriver, as I already said, you need a Torx T10 to the get the screws out. However, I would check the connectors on the circuit board first before you pull it apart.
Old 28-01-2009, 12:33 PM   #5 (permalink)
Arh sory mate cheers for the response, i didn't understnad what you were saying at first however after detaching the neck and looking at the arse end i found the green circuit board with the brass disc's you spoke of, sure enough they had little black dots on them, i have tryed to clean them with a cotten bud however they don't seem to wanna shift. Is there any cleaning fluid i could use to help get these off?
Old 28-01-2009, 6:02 PM   #6 (permalink)
I've re-edited my post after realising that some of it made no sense.
Anyway, I suspect that if the dots won't shift with a dry cotton bud, then the connectors are gored meaning they are damaged and the problems will only get worse. Sadly, this is quite a common problem with this guitar (despite its brilliance when it works properly). At this point I'm pretty much out of ideas as fixes seem to either revolve around the use of a soldering iron, which is something I know nothing about or getting a new one.
When this happened to me, I ended up getting a new one via the HMV £35 for GHIII bundle deal and then selling the sealed game and old Les Paul on eBay (I did sell it as faulty!), which pretty much made back the £35 outlay.
Other than that I'm not sure what else to suggest.
ajwatson (28-01-2009)
Old 28-01-2009, 6:44 PM   #7 (permalink)
cheers dude
Old 28-01-2009, 7:51 PM   #8 (permalink)
Thanks: Gave 51, Got 10
I had a problem similar to this where my blue button was a bit flaky. I did this and it really helped.
Doll is offline   Reply With Quote
ajwatson (29-01-2009)
Old 29-01-2009, 12:55 PM   #9 (permalink)
wicked i can uderstand that thiis would stop the neck from wolbleing but how does it prevent laggy buttons????
Im going to give it ago cheers
Old 31-01-2009, 10:08 PM   #10 (permalink)
Dunno mate, worth a shot though.
Old 03-02-2009, 11:46 AM   #11 (permalink)
Thanks: Gave 253, Got 288
By making the neck stable so it doesn't rock around the contact between the neck and body PCB's remains perfect. When the neck wobbles it actually rubs the contacts away which is what eventually causes unresponsiveness in the buttons, doing this can keep the two halves in good contact so the problem doesn't occur. Of course if your contact plates are damaged too much in the neck already then this will not make a difference.
I'd love to list all my really cool AV equipment here but I feel too ashamed and embarrassed...
Proud owner of Xbox 360, PS3 and Wii!
shagaboopon is offline   Reply With Quote
Old 04-02-2009, 12:03 PM   #12 (permalink)
Thanks: Gave 123, Got 75
just tried this and guitar is perfect now
systemsdead is offline   Reply With Quote
button, guitar, les, paul, red, wireless, working
Copyright © 2000-2010 M2N E. & O. E.
