Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Gaming > Xbox Gaming > Xbox 360 > Xbox 360 Games > Guitar Hero Xbox 360
Latest AVForums Movie Reviews
Clash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray Review
Toy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD Review
Old 18-01-2009, 9:47 PM   #1 (permalink)
Thanks: Gave 1, Got 5
Drums dying altogether- warning for those considering buying them
Well my crappy drums have now died altogether.
Had 3 days of great play
Then Red pad started to register a hit when striking any of the other pads
Got the midi cable, tweaked it - all OK.
Then the pedal started getting super sensitive.
A bit of insulation tape placed on the pad to dampen it a little solved that.
Then the whole kit started randomly powering off mid play. Started every few tunes, then today played 2 1/2 songs with it cutting out about 6 times until finally cut out and won't power up again. Not the batteries- know that for a fact (Changed them 20 times!).
All in all- shocking piece of rubbish. Was really looking forward to playing with it, and did enjoy it to begin with, now I just totally regret buying the whole thing as its been an over priced disappointment. I mean, just look at the lengths people have had to go to to repair and tune them let alone anything else, seems way too much effort vs reward to me.
If you're not up for all that, seriously recommend you don't bother buying them!
eddyr is offline   Reply With Quote
Old 18-01-2009, 10:36 PM   #2 (permalink)
Thanks: Gave 2, Got 23
Re: Drums dying altogether- warning for those considering buying them
That's a shame that you've had such bad luck with them, but they're not all rubbish. I've had no problems with mine.
candi is offline   Reply With Quote
Old 19-01-2009, 12:10 PM   #3 (permalink)
Thanks: Gave 226, Got 407
I've spent many an hour beating away by myself with no problems
Any manufactured product will have a percentage that dosent fall within expected tolerances and fails early, you might just have a dodgy set, so worth trying to get exchanged/fixed and see if the new one is better.
Gaming tag = Stinja
Stinja is offline   Reply With Quote
Old 19-01-2009, 12:32 PM   #4 (permalink)
Thanks: Gave 145, Got 417
And I thought this was a family forum!!
RIP Dodgybob.
The world will look up and shout "Save us!"... And I'll whisper "No."
Captain Speedy is offline   Reply With Quote
edwardtickle (09-02-2009)
Old 19-01-2009, 7:52 PM   #5 (permalink)
I'm hoping it is just a naff set!
Gamestation picking it up tomorrow, shall see when I get a replacement!
Annoyingly they're having to take the whole lot back, so can't play guitar while I'm waiting, knowing my luck the replacement Guitar will probably play up
Old 21-01-2009, 9:38 AM   #6 (permalink)
Thanks: Gave 161, Got 72
i prefer the drums so much more than the rock band set, but they are of lower quality internally.
ive reapired my red pad about 5 times now, but dont regret buiying them.
just remembering the clack clack clack everytime i hit the rock band set convinces me i did the right thing changing.
Toshiba 37XV503DB / Xbox 360 Elite / Logitech Z-5500 / Playstation 3 80Gb & PlayTV / Dell Inpsiron 9400 / Ipod Touch 8Gb / Nintendo DS Lite / Logitech Harmony 555 / LG KP500 Cookie / Turtle Beach X4's
Yubious is offline   Reply With Quote
Old 21-01-2009, 10:17 AM   #7 (permalink)
Thanks: Gave 19, Got 32
we're on our fourth set
1st set - red pad became unresponsive
2nd set - foot pedal unresponsive out of the box
3rd set - yellow cymbal became unresponsive (i think the kids may have had something to do with that)
thankfully I bought ours from Costco who's returns policy is 2nd to none
KingEdward is offline   Reply With Quote
Old 21-01-2009, 1:45 PM   #8 (permalink)
Thanks: Gave 4, Got 280
"They can pick up the standalone version of World Tour and use [Rock Band] instruments, and when they break they can buy ours" - Brian Bright, 21st August 2008
AVForums Guitar Hero III Tournament Winner 2008
Twitter | Chasing The EffSee - Latest post: Expert Vocal FC #70 + #71 (Gives You Hell, Just For Tonight)
lentini is offline   Reply With Quote
Old 21-01-2009, 8:50 PM   #9 (permalink)
Gamestation collected next day, to their credit -waiting to see how long it might be before a replacement will arrive.
Old 01-02-2009, 1:06 PM   #10 (permalink)
Been away for a week and returned to find a new set delivered.
Been playing lots since last night, and so far new set seems a LOT better, no tuning yet required it's all spot on. Must note that its the supposed newer set, with the smooth cymbals and philips screws underneath, all in all so far so good
Old 06-02-2009, 9:20 PM   #11 (permalink)
Thanks: Gave 170, Got 599
Its a bit obvious I know but mine started cutting out, ie losing connection to my console.
Turns out a new set of batteries were in order.
SD
Opinions expressed here are my own and do not represent those of the AV Forums or its associated websites
Please read the trading rules
SCAMMERS ARE TARGETING THE PM SYSTEM. SEE HERE FOR DETAILS. PLEASE BE EXTRA VIGILANT
Gordon B is offline   Reply With Quote
Old 07-02-2009, 10:48 PM   #12 (permalink)
Thanks: Gave 2, Got 0
Today my drums have stopped working as well, well when i say "not working" i mean one of the symbols (the yellow one) just completly stopped picking up pressure against its sensor. I figured out that it was the little cable underneath the symbol. It had been pushed in way too far and hard therefore scrambling up the wires and circuit board.
That £60 gone down the drain, only lasted a month .
Everything else works fine though.
So just be careful when you plug in the wire underneath the symbol. DO NOT PUSH IT IN HARD AND QUICKLY OR ELSE IT WILL MESS UP YOUR DRUMS.
MELONzZ iG0D is offline   Reply With Quote
Old 08-02-2009, 6:38 PM   #13 (permalink)
try this link mate
Answer
go through the steps & see how you go
ignore the fact that it relates to the guitar, it asks a few steps along the line what instrument you're having problems with
altogether, buying, drums, dying, warning
Copyright © 2000-2010 M2N E. & O. E.
