AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Graphics Cards, TV Tuners and Webcams
LinkBack Thread Tools Display Modes
Old 22-01-2008, 7:05 PM   #1 (permalink)
Samsung SM2032BW
Hello everyone! My first post, but I have been lurking around for some time now and got lots of useful information and equal amounts of confusion!
I bought a SM2032BW monitor on Sunday (from Comet, 169pounds - cheapest I found). The monitor had a very very bright stuck red pixel which was showing only on black and blue background.
After using JScreenFix (not sure if Im allowed to post links to products, so just google it) for a whole day, the pixel got unstuck and I have not seen it again. To begin with it was bright but started flashing and changing colour, later on it faded and faded and faded.....until it vanished!
Hope this helps people with similar issues.
All in all I am quite happy with the monitor, except the cheap vga cable it came with (it also had a dvi cable but I have not seen it yet). Unfortunatelly my laptop does not support the native resolution, so I am missing out from this and the lack of dvi output, but im not too fussed about it. The size of 20" is good for me and to be honest when I compared the 20" and 22" side by side at the shop, the size difference did not justify the 45pounds difference.....
Would anyone suggest any good settings they use on this?
Take care,
Solomon
solpap is offline
Old 23-01-2008, 7:02 PM   #2 (permalink)
Thanks: Gave 13, Got 3
Re: Samsung SM2032BW
Ive got this monitor and ive got 2 white stuck pixels which are on the outsides of the screen and i cant get them to shift so might try that site you listed and run that all day.
as for settings, i hear the software which comes with the monitor is suppose to be very good so i might give that ago aslong as it works with Vista
Mikey86uk is offline
Old 23-01-2008, 10:45 PM   #3 (permalink)
Hello,
yes give it a try...I was sceptical to begin with, but it worked! its free anyway, so nothing to lose really. It does work better with Firefox, in the sense that you can run it in a small window and place it on the stuck pixels. Otherwise it runs full screen. Note that on the website, if you dont open it with Firefox it doesnt give a download option.
With regards to settings, I must admit that the cd (or dvd?) didnt do anything (I run XP). I had to install the drivers manually. I gonna have a better look though...
Hope your pixels get unstuck!
solpap is offline
samsung, sm2032bw
Refbacks are On
Thread Thread Starter Forum Replies Last Post
PC Monitor 20" (Samsung SM2032BW or SM2032BW) Turbotit Computer Monitors 0 15-11-2007 8:37 PM
SAMSUNG SM2032BW 20" WIDESCREEN TFT MONITOR for PS3? munday63 LCD Televisions 2 14-09-2007 2:44 PM
Wall mounts for Tosh 37wlt58 & Samsung LE32R51BD and Samsung LE26R51BD jeeps LCD Brackets and Mounts 6 25-07-2007 6:51 PM
Samsung LE26R74BDX Vs Samsung LE26R87BDX Vs Samsung LE26R88BD Y2Doddy LCD Televisions 15 11-06-2007 9:33 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
