AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Graphics Cards, TV Tuners and Webcams
LinkBack Thread Tools Display Modes
Old 14-01-2008, 7:23 PM   #1 (permalink)
Thanks: Gave 37, Got 1
Best usb tv card for Vista?
Evening all.
I was wondering if anyone could recommend a decent TV card for a Vista Laptop?
I purchased a Dazzle TV package from PC world and it was appauling. The software (PC TV) was plagued with bugs and the remote control wouldn't work properly.
Any advice would be greatly appreciated.
spidey2k7 is offline
Old 14-01-2008, 7:35 PM   #2 (permalink)
Thanks: Gave 3, Got 33
Re: Best usb tv card for Vista?
Do you need analogue or digital?
Chris.Day is offline
Old 14-01-2008, 7:36 PM   #3 (permalink)
Sorry, preferably digital.
Old 14-01-2008, 9:34 PM   #4 (permalink)
Smile Re: Best usb tv card for Vista?
I had the same problems with my Dazzle usb TV stick. I solved the problem by downloading the latest software from the pinnaclesys website, the software bundled with the hardware wouldn't work properly with Vista. If you haven't done this I would give it a go.
lugonn is offline
Old 14-01-2008, 10:12 PM   #5 (permalink)
Yeah I did have a look on the Pinnacle site, trouble is my model isn't listed with any of the PCTV versions as 'Supported Hardware'.
Suppose I could give the latest version a go. Did you get a remote control with your hardware?
Old 15-01-2008, 8:37 PM   #6 (permalink)
No, I bought the cheap version just £25, couldn't see the point of a remote when I'm sat at the computer.
Looking at the website it can be difficult to work out which product is which as they all seem to be referred to by the same name, it's best to go by the model number. Do you know what the model number is for your hardware? On mine the model number is on the underside of the TV stick.
Try using this address and looking down the left hand side for your model number
http://www.pinnaclesys.com/vista/vista_tv_uk.asp
When you click on the link for your model it takes you to a general download page so be sure to scroll down to the correct software version. As some models are supported by more than one piece of software make sure you use the one listed on the page of links as the other one is just a beta version I believe.
Hope this helps
lugonn is offline
spidey2k7 (16-01-2008)
Old 16-01-2008, 2:40 PM   #7 (permalink)
Hope this helps
Thanks for your help.
Old 16-01-2008, 10:54 PM   #8 (permalink)
Well, I tried the latest software but no joy, so the Pinnacle product went back and I exchanged it for a Hauppauge Win TV Nova-T...
Having less luck with this than I did the Pinnacle setup! Arrrrggggghhhhhhh
Have updated to latest software (win tv 4.1) and drivers, and again, no joy.
Hardware is recognised in the devices list and is deemed to be working normally.
The problem occurs when trying to scan for channels (within win TV and a similar pattern occurs in Media Centre). You click the scan button and you get a notification that the software is scanning, but thats it, it doesn't progress any further. I had left it in this state for half an hour.
So I just don't know. I thought maybe my fortunes would change going to a different manufacturer, but clearly not. I'm now starting to question if it's the laptop or OS that's causing the conflict.
Laptop Spec:
Dell Inspiron 1501
AMD Turion 64 MK36 2Ghz
1GB Ram
Vista Home Premium 32 Bit
Please can someone advise? Have any of you experienced problems like this?
Help!!
Old 17-01-2008, 7:00 PM   #9 (permalink)
What type of antenna are you connected too when scanning? I found the supplied aerial pretty poor. I connected my computer to my household aerial for the initial scan and changed to a portable aerial when the channels had been saved.
lugonn is offline
Old 17-01-2008, 7:06 PM   #10 (permalink)
Save this to your desktop:
http://www.quantexzone.com/files/scb...nelsBDA_UK.exe
Run it, and then select Option 1 to scan all UK frequencies. It will create a file called ScanChannelsBDA.log on your desktop. If you zip it up and attach it I will take a look at it, because you can tell from that whether the card is trying to scan or not. Generally, the supplied aerial is completely useless.
Old 17-01-2008, 7:14 PM   #11 (permalink)
y2k
y2k's Avatar
Thanks: Gave 108, Got 160
What do you have a pcmcia or express slot on your laptop? Avermedia do a 34mm hybrid expresscard thats supposed work well with vista. I had a pinnacle hybrid pro usb stick and couldn't get a proper signal with either the analogue or digital tuner on it even with a rooftop aerial so I took it back, I have read that hauppage are probably the best tv tuners but they dont do the 34mm expresscard that im looking for.
y2k is online now
Old 17-01-2008, 9:19 PM   #12 (permalink)
I'm using the Nova-T usb stick. I've connected the standard aerial, but it's running through a powered booster.
I will get the download and forward the results to you chris.
Thanks for your assistance people.
Old 19-01-2008, 2:07 PM   #13 (permalink)
I've seen what you're seeing a couple of times (Strength=0, Quality=-100). I my case, unplugging and replugging in the Nova-t Stick after installing the drivers got it working.
Generally, if you see Strength=0, it means that the driver is not functioning correctly. Even with no signal (or a dead tuner) you would see varying strength figures. (note: this applies to the Nova-t Stick only; some tuners such as the HVR-900 report 0 when there is no signal lock).
Old 19-01-2008, 2:45 PM   #14 (permalink)
Thanks for your help, much appreciated. I will give that a go and see how I get on.
Old 19-01-2008, 4:23 PM   #15 (permalink)
No luck with that. It's just really odd. The device is present in the dev manager and has no conflicts and registers as working properly.
I'm not sure what else to try now to be honest.
card, usb, vista
Refbacks are On
Thread Thread Starter Forum Replies Last Post
vista & hauppauge TV Card Wray2k Windows Vista 1 11-07-2007 4:01 PM
Firewire PCI card and Vista mk Camcorders and Video Editing 3 08-06-2007 12:09 PM
Which DVB-T card for Vista MCE?? wyerd Windows Vista 11 30-05-2007 6:48 PM
Vista PVR Card thefair1973 Computer Systems 0 05-04-2007 1:18 PM
SKY through DVB-S card(s) on VISTA Davehorne Windows Vista 3 12-01-2007 8:01 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
