3.5 million visitors each month
Go Back   AVForums.com > Computers > Graphics Cards, TV Tuners and Webcams
Today's price checkPowered by
Gigabyte GeForce 7200 GS 256MB GDDR2 / PCI-E / SLI / DVI / TV-OUT
Hauppauge WinTV HVR-900
Logitech QuickCam Pro 9000
Microsoft LifeCam VX-3000
Gigabyte GeForce 7200 GS 256MB GDDR2 ...
Hauppauge WinTV HVR 4000
Logitech QuickCam for Notebooks Pro
Sapphire Radeon HD 3850 512MB GDDR3 /...
KWorld PlusTV Dual DVB-T PCI
Toshiba PX1342E-1 Webcam
Sapphire Radeon HD 4650 1GB DDR2 / AG...
 More...Prices updated November 8th at 1:30am and include delivery.
Nokia N97 Discussion Thread kamy100 Nokia Mobile Phone Discussions 931 05-11-2009 4:59 PM
Samsung 32B6000 or Panasonic TXL32V10 plz help Sthal LCD Televisions 4 03-07-2009 10:38 AM
Trader Ratings - How to get the URL details?? Accylad Mac Hardware, OS and Software 5 01-07-2009 10:31 PM
BET HD tuning details Ray_Woodward Sky HD 0 01-07-2009 3:52 PM
Star Trek (2009) blue ray details Battlestar Movies and TV Programmes On Disc and Downloaded 2 29-06-2009 6:58 PM
Old 04-07-2009, 9:22 PM   #1 (permalink)
Thanks: Gave 9, Got 5
Question PLZ Help HDMI@1920*1200 drowning in detail
Drowning in detail here, what I am after is a quiet ATI card to drive 2 24” monitors (1920x1200 & no HDMI) which maybe also able to do 2 30” mons in 3-5 years (well u can dream). I am not a serious gamer.
Unfortunately I got a MSI HD 4670 512MB GDDR3 Dual DVI PCI-E Graphics Card (ebuyer 150349) because in the extended spec it said 2*2 dual-link dvi, so that’s got it all covered. However when it turned up it has a DVI and a HDMI.
At the moment I don’t have access to a 1920*1200 monitor so cannot test any of this and anyway u should not use something that you are looking at returning.
Now I thought HDMI only did 1920*1080 so am I screwed?
As an aside somewhere on the ATI site I saw the 4670 can only do dual link on the primary display and only single link on the secondary display, is this correct?
On the MSI box it talks about ‘MSI Exclusive Mazarine DVI’ which is where via a dvi->hdmi adapter you can have resolutions up to 1920*1200 or higher???
I’ve been looking all over and am now just fine detailed out.
Will I be able to drive 2 1920*1200 mons using this card, presumably with a HDMI-DVI adapter?
If so could I do the same with a 4350/4550 with the same output interfaces on it?
Is there such a thing as a HDMI-DVI adapter?
Any thoughts would really be appreciated.
Thanx
Paul
2*DIY PC->Asus Xonar D2/USB->(Bel Canto S300IU/Sony STR-DB930->2*Kef Q35+Kef Q9c+2*Eltax+Velodyne CHT-10) & Sharp 46" + Technosonic 32"
Paul666 is offline   Reply With Quote
Old 04-07-2009, 9:42 PM   #2 (permalink)
Thanks: Gave 1, Got 335
Re: PLZ Help HDMI@1920*1200 drowning in detail
HDMI does 1920x1200@32@60Hz fine (I'm using a 4850 myself for that right now in fact). HDMI is really just single-link DVI-D with audio and control channel added for TVs and similar so anything single link DVI-D can do, HDMI can do as well. And as they're the same signals adapters just change the plug so they're cheap and plentiful - HDMI to DVI cables are availible as well.
I believe you will need proper dual-link DVI ports to drive two 30" monitors though, HDMI does come in a dual-link varient but I've been told that it needs the bigger HDMI connector and not the common one.
The 4350 page also states it can do 1920x1200 on the secondary and 2560 on the primary via DVI: ATI Radeon™ HD 4350 Graphics - GPU Specifications
EDIT: Nvidia have a list of their GPUs that support Dual Dual-link DVI: http://www.nvidia.com/object/extreme_hd_gpu.html
EndlessWaves is offline   Reply With Quote
Paul666 (04-07-2009)
detail, drowning, hdmi@, plz
