GFX Card for twin Monitor setup
Old 20-11-2008, 11:45 AM   #1
Conspicuous Member
Paul_T's Avatar
21,874, Level: 35
Points: 21,874, Level: 35 Points: 21,874, Level: 35 Points: 21,874, Level: 35
Activity: 15.2%
Activity: 15.2% Activity: 15.2% Activity: 15.2%
Thanks: Gave 190, Got 733
I'm looking a GFX card to run 2 monitors.
1 - 24" Widescreen @ 1900x1200
2 - 19" @ 1280x1024
I may well do a little gaming and Blu-ray watching on the larger monitor but the main use will be for CAD.
Budget - was hoping about £50-60
Thanks in advance.
Old 20-11-2008, 12:36 PM   #2
_Mazza_'s Avatar
2,763, Level: 12
Points: 2,763, Level: 12 Points: 2,763, Level: 12 Points: 2,763, Level: 12
Re: GFX Card for twin Monitor setup
For that price bracket the 4670 is probably the best value card, but a quick google search shows that some people have had problems with dual monitors so I'd check that before buying.
Old 21-11-2008, 9:38 AM   #3
marchudman's Avatar
6,314, Level: 18
Points: 6,314, Level: 18 Points: 6,314, Level: 18 Points: 6,314, Level: 18
Thanks: Gave 24, Got 66
The bigger screen resolution will need a bit more grunt to run, I'd be tempted to put a bid in for a second hand 8800GT - had a quick look on ebay and there are quite a few on there, just amke sure you get the 512mb version.
With a bit of luck you could get one for £60
Old 21-11-2008, 12:53 PM   #4
Conspicuous Member
Paul_T's Avatar
21,874, Level: 35
Activity: 15.2%
Is the amount of onboard RAM the main consideration for this - I've seen a few card with 1gb on board and thought it would be overkill for my needs, might be worth looking into to be on the safe side...
Old 21-11-2008, 1:28 PM   #5
5,672, Level: 17
Points: 5,672, Level: 17 Points: 5,672, Level: 17 Points: 5,672, Level: 17
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 5, Got 164
not really - video memory of that size (and 1 GB to 256mb is like a F1 car compared to a normal car when you only want to go to the shop.)
256mb - 512mb is more than enough unless you are playing some heavy duty games at high res. (even 512mb is a bit much really)
Powered by
 Latest popular product prices
Hauppauge PCTV picoStick 74e
1 price
 £19.97 Click to show/hide the offers
1 price
Hauppauge WinTV Nova-T USB Stick
2 prices from
 £29.99 Click to show/hide the offers
2 prices from
Vtx3d Radeon HD 5450 (VX5450 512...
1 price
 £24.99 Click to show/hide the offers
1 price
KWorld DVB-S100 PCI
1 price
 £27.54 Click to show/hide the offers
KWorld DVB-S100 PCI
1 price
 Updated February 11th at 12:30pm. Prices include delivery.
