My 7010i arrived from scan yesterday, I also ordered a PCIe X1 flexi riser (reversed) from LinITX to allow me to fit this card in my Artisan box.
All good, the card fits no problem, and the 7cm flexi riser is plenty long enough. The only concern here was the fact the risers ribbon connector fouls on some capacitor cans before it was fully inserted into the PCIe on the motherboard (Intel DG33TL). This is only for one of the PCIe slots and there is still plenty of friction so I am not that worried but it may be better to go for the normal flexi riser for this slot (rather than the reversed one) I'll investigate further.
The card was detected in MCE (vista32) and I just let it do its thing (as previously suggested, with no problems.
Scanning for channels seemed a bit hit and miss, first scan found 22 channels, after another I got to 36 and was not able to find any more.
Started to preview some TV, all looked good. Channel changing can be really slow ranging from 1-5 secs, the viewing channel will freeze instantly and then you wait, sound for the selected channel seems to come in fractionally before the picture starts but all is synced.
Tried putting it to sleep, when it came out of sleep I got the message "No Tuner Found!" Just like the BlackGold!!!!!!! I thought I should perform a full reboot before I call the jury back. After the reboot I could not repeat this or any other failure, tried dual recordings etc. All seems good!
Performed some more scanning for channels, now up to 70..
I will test it out for a week and if all is still well I will buy another 7010i and flexi riser, giving me 4 CHANNELS!!!!!! All for less than a BlackGold BGT3540!
Needless to say the BlackGold card is going back
