Originally Posted by FallenAngelX GTA 4 Icenhancer
Skyrim Enb series |
GTA IV and Skyrim both like lots of CPU so are you sure your current one is sufficient?
Battlefield 3, which doesn't need much, does suggest you could do with the graphics upgrade though.
As to latest results, Techpowerup are pretty good,
here is a review using the latest beta drivers and most of the games on your list. They are testing at 1920x1200 and and maximum settings which is obviously unobtainable for you (unless you're buying multiple cards) but it should give you an idea of relative performance in a worst case scenario.
