10-08-2008, 4:44 PM
#1 (permalink)
| | Member
Thanks: Gave 0, Got 1 | GTAIV barely playable on my New HD TV???
GTA IV looks sumptuous and gorgeous on my new Bravia 40w4000. HOWEVER when the game is in night time the darkness means I can barely see anything. The game goes uber-dark.
My friend had an interesting suggestion that many HDTV's have automatic sensors in them to increase the brightness and black levels. I think in GTA IV that the TV thinks it should really emphasise the blacks and so automatically makes the game incredibly dark.
Anyone else have this issue. It's annoying, because I have my settings really well configured for 99% of PS3 games, but its just GTA IV at night.
10-08-2008, 4:49 PM
#2 (permalink)
| | Member
Thanks: Gave 34, Got 28 | Re: GTAIV barely playable on my New HD TV???
Try adjusting the brightness a little in the games menu hope this helps
XBL:Brum1875 PSN:Brummy1875
10-08-2008, 4:51 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 214, Got 156 | Re: GTAIV barely playable on my New HD TV??? Quote:
Originally Posted by hummersav Try adjusting the brightness a little in the games menu hope this helps  | Was just about to say the same thing! Should make a big difference
__________________ CLICK HERE TO VIEW MY HOME AV PICS Pioneer PDP-5000EX, Bravia 46Z,40Z & 32W, Sky HD1TBx2, Arcam AVR600, ArcamDV139, B&W XT Series, B&W P5 headphones, Shure SE530, B&W Zepp and Mini Zepp, PURE Sensia x'2, iMac i7 Quad |
10-08-2008, 4:59 PM
#4 (permalink)
| | Prominent Member
Thanks: Gave 24, Got 391 | Re: GTAIV barely playable on my New HD TV???
I doubt it's that, my 40W3000 auto-dims when there is a dark scene, unless it's in Game Mode, i would have thought the newer models do exactly the same...
10-08-2008, 6:02 PM
#5 (permalink)
| | Member
Thanks: Gave 7, Got 6 | Re: GTAIV barely playable on my New HD TV???
When i bought gta i could'nt see a thing on my tv. Had to turn the in-game brightness up. I havn't got a hdtv though but its worth a try first.
10-08-2008, 6:16 PM
#6 (permalink)
| | Member
Thanks: Gave 17, Got 34 | Re: GTAIV barely playable on my New HD TV???
Make sure the PS3 settings are not on full RGB, keep it limited.
BFBC2, BF1943 - oska75
10-08-2008, 6:32 PM
#7 (permalink)
| | Prominent Member
The new Sony Bravia's have built-in auto-dimming features, basically to try and hide any clouding in the panels after the 40W2000's panel was complained about so much. If there's hardly any light in the scene and it's not moving, the panel will dim once, then dim again till it goes almost black, it turns the backlight off. The only way round this is using "Game mode", but this limits the other options the panel has available.
10-08-2008, 7:03 PM
#8 (permalink)
| | Member
Thanks: Gave 8, Got 3 | Re: GTAIV barely playable on my New HD TV???
I had similar problems with the Xbox 360 version of GTA4 on my set, night-time was all but unplayable. The solution I stumbled upon was turning up the in-game contrast setting which worked a treat. Might be worth giving it a try.
10-08-2008, 9:29 PM
#9 (permalink)
| | Moderator
Thanks: Gave 972, Got 792 | Re: GTAIV barely playable on my New HD TV???
I had a similar problem with GTA on a D3000. I simply turned up the in game brightness as suggested already here by others. I don't have the auto dimming feature on though as imo it's too imprecise and darkens things too much.
__________________ Blu-ray and DVD Reviewer
The Best Blu-ray and DVD Resource AVForums Movie Reviews Bookmark it now! My opinions expressed here are not necessarily those of the AV Forums or the associated websites |
12-08-2008, 3:12 PM
#10 (permalink)
| | Member
Thanks: Gave 4, Got 4 | Re: GTAIV barely playable on my New HD TV???
You can turn off the auto light sensor on the w4000 in Settings - Features - Light Sensor OFF.
18-08-2008, 10:21 AM
#11 (permalink)
| | Member
Thanks: Gave 2, Got 4 | Re: GTAIV barely playable on my New HD TV???
I also have the 40W4000 and found the night missions very dark. I have the light sensor off in the TV settings and then adjusted the colour, contrast and brightness in the Game Display settings - looks just fine now.
03-09-2008, 6:42 PM
#12 (permalink)
| | Senior Member
Thanks: Gave 8, Got 154 | Re: GTAIV barely playable on my New HD TV???
the game is far too dark, its a well known problem. try gauging your tv's black performance on a game other than gtaIV......
onkyo 805 : PS3 slim : a mish-mash of mission and tannoy speakers : 15" sealed subwoofer .................................................. ..............................................
other consoles, a laptop, a pc ect ect ect.
