Is it possible to use a 360 modena pro wheel ?
Old 31-03-2009, 12:33 PM   #1
2,733, Level: 12
Points: 2,733, Level: 12 Points: 2,733, Level: 12 Points: 2,733, Level: 12
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 253, Got 267
I have a Thrustmaster 360 Modena Pro USB steering wheel, and it would be nice if I could use this with GT5, but the game only appears to support specific Logitech hardware.
I would like to confirm that this wheel will definitely not work with the game before I purchase a Logitech DFP (can't justify a G25!)
Thanks.
Old 31-03-2009, 9:59 PM   #2
2,192, Level: 10
Points: 2,192, Level: 10 Points: 2,192, Level: 10 Points: 2,192, Level: 10
Thanks: Gave 31, Got 21
Re: Is it possible to use a 360 modena pro wheel ?
Thanks.
Try plugging it in?
Old 01-04-2009, 8:12 AM   #3
2,733, Level: 12
Activity: 3.4%
Originally Posted by Mike Spence View Post
Try plugging it in?
Yes I did try that. Some of the buttons did allow me to navigate through the menus, but the steering and accelerator/brake did not work.
Ok, a more general question might be, is anyone using a wheel other than those specifically listed in the hardware section of the setup options?
Old 01-04-2009, 5:05 PM   #4
bungieben's Avatar
4,820, Level: 16
Points: 4,820, Level: 16 Points: 4,820, Level: 16 Points: 4,820, Level: 16
Thanks: Gave 36, Got 31
Yes a G25...... First connect you handset as controller 1 then connect the wheel as controller 2 if u get no joy then i think you will be spending some cash.
