Okay, after making the decision to buy a Wheelstand Pro, the packaged arrived today and I thought I'd write a quick review and show pictures of what's in the box and how it all fits together.
wheel stand pro
Mine was bought with the G25 attachment which costs £99. I paid via Paypal which made the order process very quick. The order was placed on the 12th with delivery today, 20th, seems quite slow as it was held in Customs for several days, I have heard some people getting theirs quicker, guess it's the luck of the draw, or your shipping coincides with the weekend.
1. The package was a little damaged and seems to have had extra tape placed around the box. The contents had minimal bubble wrap and did seem to rattle around in the generous box, thankfully no damage.
2. The stand comes already well assembled, small pack of bolts, allen keys and a spanner, plus the G25 bracket and additional bolts.
3. The instructions seem very clear and simple, nothing too complicated to get confused with.
4. What’s initially impressed me was the solidity and strength of all the materials, no plastics or flimsy construction. All steel sections/tubes were either powder coated or chrome plated. The clamps are very strong and from initial tightening, seem to hold the vertical post very secure.
5. Setting up the G25 pedals was very easy and from past studies of other versions of the stand, they have now provided a metal plate to fix the pedals to the frame. It seems to work and is simple and effective.
6. Clamping the steering wheel to the top plate requires the gear shift plate to be placed on top before clamping. The bolds provided didn't seem to be used here and all that secures the wheel to the top plate is the wheel clamps themselves, so far, it seems to be okay.
7. The gear shift clamps don't extend far enough up to clamp to the plate. They have provided 2 bolts to go through the underside of the plate and into the gear shift. This works well, but immediately you start playing the bolts start to rattle around and prove a distraction. The solution, some electrical tape over the clamp bolts to stop them rattling.
8. The Wheelstand Pro provides plenty of adjustment for all types of chairs and positions. In operation there seem very little movement from the vertical post and it would suggest that it could take some serious FFB to make it move at all. One thing that did distract me at first was the resonance and vibration through the frame when the FFB kicked in whilst hitting a heavy kerb in GT5P, something that I got use to quite quickly so not really any concern.
9. Overall, thoroughly recommend getting this if, like me, you need the space and don’t do racing games every day, yet need something serious setup when you do. It seems expensive for what you get, but then again, most consumables for the PS3 are!
Score 9 out 10,
