Logitech G25
Old 15-06-2009, 5:08 PM   #1
10,453, Level: 24
Points: 10,453, Level: 24 Points: 10,453, Level: 24 Points: 10,453, Level: 24
Activity: 14.8%
Activity: 14.8% Activity: 14.8% Activity: 14.8%
Thanks: Gave 89, Got 262
Logitech G25
For anyone interested, the G25 is currently £127.98 delivered at novatech
Old 15-06-2009, 6:36 PM   #2
8,390, Level: 21
Points: 8,390, Level: 21 Points: 8,390, Level: 21 Points: 8,390, Level: 21
Activity: 14.2%
Activity: 14.2% Activity: 14.2% Activity: 14.2%
Thanks: Gave 223, Got 512
Re: Logitech G25
That really is a fantastic price as it's a quality piece of kit.
Old 18-06-2009, 5:07 PM   #3
7,647, Level: 20
Points: 7,647, Level: 20 Points: 7,647, Level: 20 Points: 7,647, Level: 20
Thanks: Gave 9, Got 130
Re: Logitech G25
Overclockers.uk are selling the G25 for £124.99.
Logitech G25 Racing Wheel (963416-0120)
Old 18-06-2009, 7:15 PM   #4
2,503, Level: 11
Points: 2,503, Level: 11 Points: 2,503, Level: 11 Points: 2,503, Level: 11
Thanks: Gave 30, Got 7
Re: Logitech G25
+£9.95 for delivery though
cheaper at dabs £131.42 with delivery at dabs
dabs.com - Logitech G25 Racing Wheel (963416-0120)
Old 18-06-2009, 9:42 PM   #5
7,647, Level: 20
Re: Logitech G25
When i bought mine from them i got it with free delivery.
You have to use there forum and from what i can remember if you had posted on the forum over 200 times you got free delivery.
Old 02-07-2009, 12:01 PM   #6
7,259, Level: 20
Points: 7,259, Level: 20 Points: 7,259, Level: 20 Points: 7,259, Level: 20
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 38, Got 62
Re: Logitech G25
very tempted with one of these, is there much improvement over the driving force pro what i have got ??, also just seen on gt forums website and various others that the g28 could be coming out at same time as gt5
Old 02-07-2009, 11:26 PM   #7
5,181, Level: 17
Points: 5,181, Level: 17 Points: 5,181, Level: 17 Points: 5,181, Level: 17
Activity: 2.8%
Activity: 2.8% Activity: 2.8% Activity: 2.8%
Thanks: Gave 327, Got 145
Re: Logitech G25
Just bought a G25 and is a better quality wheel in every respect to the DFP which itself was a good bit of kit.
Old 03-07-2009, 5:44 PM   #8
2,503, Level: 11
Re: Logitech G25
£99.99 at play using code GRID25
Play.com (UK) : Logitech G25 Racing Wheel : Computing - Free Delivery
Old 03-07-2009, 9:26 PM   #9
7,259, Level: 20
Activity: 1.4%
Re: Logitech G25
hmmm that sound a good deal for a g25, now just to decide if to wait for the g27 or not
Old 08-08-2009, 12:03 AM   #10
9,324, Level: 23
Points: 9,324, Level: 23 Points: 9,324, Level: 23 Points: 9,324, Level: 23
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 140, Got 282
Re: Logitech G25
Instead of creating a new thread I though would just add to this one & seek some opinions of people who use wheels & the G25 in particular.
I had a friend round this eve and were playing FC using the G25 on a newly acquired playseat & wheel. Now when using a pad I had used the shoulder button and was used to the concept of braking and accelerating at the same time. However, since getting the wheel I have driven as I would a normal car, suing the right foot to either brake or accelerate.
Just wondering, you guys using a wheel & pedals, do you brake and accelerate with one foot or two? If so when using a clutch do you then swap to one foot? Just curious as I think my lap times may be effect as am using one foot.
Out of curiosity I would also like to know in real life racing is one foot used or two?
Old 08-08-2009, 9:28 AM   #11
5,089, Level: 16
Points: 5,089, Level: 16 Points: 5,089, Level: 16 Points: 5,089, Level: 16
Thanks: Gave 412, Got 310
Re: Logitech G25
I use two feet for racing, pretty much always heading in the opposite direction if that makes any sense (e.g. as brake goes down, gas comes up).
Mainly been playing Ferrari challenge but it seems to swing the weight of the car around better and produce more grip into turns driving that way.
My assesment is it's not only phisically quicker but more importantly a quicker and smoother transition of weight / downforce and momentum as any time where you are off the gas and going on to the peddle (with one foot driving) the car is effectively freewheeling which means that when you then do apply the brake or gas your change of momentum is more extreem, is being applied later than you want it and you can loose grip easier.
I see it a bit like a rugby player trying to jink his way upfield to score. He wants to run straight (the quickest path allowing him to accelerate to full speed) but is also forced to go left and right to get there. He has to swing his centre of gravity from left to right to jink but really wants to keep as much momentum as he can directed in the final direction he wants to travel in.
I'm pretty sure racing drivers all left foot brake also.
Was watching the Monaco Grand Prix the other week and Martin Brundle said that a formula 1 car can change gear 50 times faster than the human eye can blink !
Can't see how it's possible tbh but he definately said it??
Magus (08-08-2009)
Old 08-08-2009, 11:27 PM   #12
Jai Jai is offline
Jai's Avatar
2,202, Level: 10
Points: 2,202, Level: 10 Points: 2,202, Level: 10 Points: 2,202, Level: 10
Thanks: Gave 6, Got 2
Re: Logitech G25
sorry but where do I put that code in on the Play.com website??? I cant find it.
Old 09-08-2009, 5:41 PM   #13
2,503, Level: 11
Re: Logitech G25
you enter the codes at the checkout screen, should be a button on the left hand side that says you have a promo voucher of something.
anyways that code no longer works, LOGITECH80 will allow you to get it for £119.99 though, that code expires 10/8/09
Old 09-08-2009, 6:50 PM   #14
Jai Jai is offline
Jai's Avatar
2,202, Level: 10
Re: Logitech G25
can't find it
Old 10-08-2009, 6:49 PM   #15
2,503, Level: 11
Re: Logitech G25
can't find it
go to checkout
sign
click continue
on the next page there will be a box on the right hand side labelled 'voucher', click on the orange button that says 'I have a promotional or discount voucher'.
Old 28-08-2009, 9:35 AM   #16
Sharpy76's Avatar
8,575, Level: 22
Points: 8,575, Level: 22 Points: 8,575, Level: 22 Points: 8,575, Level: 22
Activity: 15.5%
Activity: 15.5% Activity: 15.5% Activity: 15.5%
Thanks: Gave 545, Got 834
Re: Logitech G25
Play are doing the G25 for £99.99, only until the 31/08/09
Play.com (UK) : Logitech G25 Racing Wheel (Get An Extra £100 Off with Voucher Code: LOGG25) : Computing - Free Delivery
Old 28-08-2009, 2:56 PM   #17
Jai Jai is offline
Jai's Avatar
2,202, Level: 10
Re: Logitech G25
Brilliant price for this brilliant piece of equipment, MUST BUY NOW!
Old 31-08-2009, 12:08 PM   #18
2,525, Level: 11
Points: 2,525, Level: 11 Points: 2,525, Level: 11 Points: 2,525, Level: 11
Thanks: Gave 19, Got 17
Re: Logitech G25
I was going to order this today however the price has gone up again
I have tried to order it and looked for where to enter the code on the off chance it works but i can't find where to enter the code?
Any ideas?
Many thanks
Andy
Old 31-08-2009, 12:32 PM   #19
2,525, Level: 11
Re: Logitech G25
If anyone else has missed the PLAY.COM deal i have found it here for £105 delivered.
Logitech G25 Racing Wheel - Misco.co.uk
Has anyone used Misco and have a review at all?
Andy
Old 31-08-2009, 12:47 PM   #20
10,453, Level: 24
Activity: 14.8%
Re: Logitech G25
I've ordered monitors etc from misco before and never had a problem, although that also means I have never had to deal with their customer services etc so I can't say what they are like if you have a problem
Old 31-08-2009, 12:57 PM   #21
8,390, Level: 21
Activity: 14.2%
Re: Logitech G25
Andy
Yep, I've used Misco several times and from my experience I would certainly recommend them. Most online price search engines have a shop review, may be worth checking there if you are still uncertain. However, I'd sooner purchase from Misco than PLAY.com from past experience.
EDIT : I've also asked them to see if they are able to do any discount on price and they've been able to accomodate, however I doubt you'd get anything more off that G25 price as they were selling the G25's for £125 just a few days ago.
Old 31-08-2009, 12:59 PM   #22
2,525, Level: 11
Re: Logitech G25
Thanks for that, I always like to check someone has delt with them before, i believe you can never trust the ratings sites.
Hmmm looks like i need to speak to the mrs and see if i can find the cash then,
Andy
Old 31-08-2009, 10:16 PM   #23
Location: Born in Bristol but now in Newport, (for my sins)
26,292, Level: 39
Points: 26,292, Level: 39 Points: 26,292, Level: 39 Points: 26,292, Level: 39
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 8, Got 267
Re: Logitech G25
It looks like Play don't even have enough stock to forfil their orders.. My order was accepted on Saturday PM, but people who ordered on Friday have called Play and been told that they don't have stock.
So I have cancelled my Play order and gone for Misco instead!! With 'Quidco' the price comes in at around £1 more than Play, so its not the end of the world.
Jon
Old 01-09-2009, 10:46 AM   #24
11,048, Level: 25
Points: 11,048, Level: 25 Points: 11,048, Level: 25 Points: 11,048, Level: 25
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Thanks: Gave 271, Got 294
Re: Logitech G25
Jon
I see what you mean - I ordered on Friday but my order status at Play is 'Order Taken'. Other orders I made later on Sunday have been packed and shipped.
They'd better come good on this one, I have ordered the Wheelstand Pro in anticipation of getting the wheel, which cost £99 for the G25 version. Will be peeved if Play now turn around and say they can't fulfil the order for the G25.
I guess they have been taken by surprise at the demand.
Old 01-09-2009, 11:09 AM   #25
26,292, Level: 39
Activity: 4.2%
Re: Logitech G25
Mine too is sat at "Order Taken".. It doesn't make sense.. Surely they would only have enough 'stock' on their website to match what was physically available.
Once that number had been ordered, then the item should go 'out of stock'.. Its criminal that they allowed people to keep buying them over the weekend when they don't appear to have stock.
Luckily I spotted this mistake in time and ordered from Misco whilst they had stock... And with £3.90 back from Quidco, its only cost me £2-£3 more than Play.. And, Misco have already sent a 'you order has been dispatched' mail so its on the way.
Looks like I had batter cancel my order with Play.. Or I might just leave it there to see what happens.
Jon
Old 01-09-2009, 12:13 PM   #26
3,572, Level: 14
Points: 3,572, Level: 14 Points: 3,572, Level: 14 Points: 3,572, Level: 14
Thanks: Gave 6, Got 32
Re: Logitech G25
Grrrrr.
Well, I've cancelled and will order elsewhere at a bit more cost. I'd rather have the wheel from somewhere that is honest about the stock, and can deliver quickly, than a 'maybe'.
Old 01-09-2009, 7:29 PM   #27
Sharpy76's Avatar
8,575, Level: 22
Activity: 15.5%
Re: Logitech G25
I ordered mine Friday morning and received an email saying its been dispatched today, so fingers crossed i'll get it this week
Its a disgrace that Play let people order knowing full well that they didnt have enough stock. When they done this offer a couple of months back the stock went rapidly too so its not like they didnt know it was going to happen
Old 01-09-2009, 8:18 PM   #28
bungieben's Avatar
4,820, Level: 16
Points: 4,820, Level: 16 Points: 4,820, Level: 16 Points: 4,820, Level: 16
Thanks: Gave 36, Got 31
Re: Logitech G25
G25 rocks
Old 02-09-2009, 11:42 AM   #29
3,572, Level: 14
Re: Logitech G25
Mine arrived today (and hopefully the WSP will as well) so I'm looking forward to tonight.
I paid £35 more (overclockers) for a reliable, no-nonsense service - they've always been excellent for me - after play.com screwed up, and I'll stick to just using play.com for cheap games on occasion.
Now I just have to find a way to get the relatives off playtv
Old 02-09-2009, 12:11 PM   #30
madmurdock's Avatar
9,849, Level: 23
Points: 9,849, Level: 23 Points: 9,849, Level: 23 Points: 9,849, Level: 23
Thanks: Gave 130, Got 253
Re: Logitech G25
Yep Play.com shafted me also. Rang them today and they said they're awaiting stock. I can leave my order open, but there not expecting stock for at least 28 days.
