AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > General Home Cinema Chat
LinkBack Thread Tools Display Modes
Old 30-03-2008, 8:42 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Unhappy Samsung HT-TX35R Problem
I just got my new Samsung HT-TX35R, which is connected to my Samsung LE46M87BDX/XEU LCD TV. But the problem is that the surround sound only works when I play a DVD, how do I turn on the sound when my Virgin Box is on? Which is connected through SCART.
Does any one out there have any possible ideas or solutions?
anandpatel is offline
Old 30-03-2008, 10:33 PM   #2 (permalink)
Ben
Ben's Avatar
Thanks: Gave 1, Got 175
Re: Samsung HT-TX35R Problem
You need to connect an optical lead between your Virgin box & your Samsung HT-TX35R. If your Virgin box doesn't have an optical output, then use a twin phono lead instead. Note, both can be found cheaper on ebay if you're willing to wait for delivery
"I stand corrected" - The Man in the Orthopedic Shoes
Ben is offline
Old 31-03-2008, 1:25 PM   #3 (permalink)
Exclamation Re: Samsung HT-TX35R Problem
The only problem with that is that, my Virgin box is really old and I don't think it comes with that type of connection.
Please take a look at the attached picture of the back of the box.
Old 31-03-2008, 2:58 PM   #4 (permalink)
Ben
Ben's Avatar
No probs - just replace your current scart lead for one with an 'audio breakout' like this. It 'breaks out' the audio from the scart on your Virgin box, so you are able to connect it to your Samsung HT-TX35R for surround sound
Ben is offline
anandpatel (31-03-2008)
Old 31-03-2008, 3:35 PM   #5 (permalink)
Question Re: Samsung HT-TX35R Problem
Okay so I get some audio breaker with SCART, but then I also have a Wii which is connected with the HD COMPONENT cable, and I get the same problem sound only comes out of the TV and not the surround sound speakers.
Any hints on the problem?
P.S the COMPONENT cable is connected directly to the TV if that helps.
Old 31-03-2008, 4:26 PM   #6 (permalink)
Ben
Ben's Avatar
I didn't realise you had other devices to connect, so forget about the scart with audio breakout. Just connect either of the first two leads I mentioned between your TV & Samsung HT-TX35R. That way, whatever you're watching/playing on your TV will come through your surround system
Ben is offline
Old 31-03-2008, 6:43 PM   #7 (permalink)
So all I need to get is a Twin Phono Lead, which will be connected to my LCD TV directly to my DVD player and the I will be able to get surround sound from any AV source?
Old 31-03-2008, 8:57 PM   #8 (permalink)
Ben
Ben's Avatar
Yep
Ben is offline
httx35r, problem, samsung
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wires for a Samsung HT-TX35R/XEU? rheeley All-in-one Systems 8 26-03-2008 2:47 PM
Samsung HT-TX35R Sq1rr3ll All-in-one Systems 2 06-01-2008 6:19 PM
Samsung HT-TX35R CallumMc All-in-one Systems 1 05-01-2008 8:09 PM
Samsung HT-TX35R - HDMI Connection Problem? JPP01 Custom Installers and Installations 2 01-11-2007 1:03 PM
Samsung HT-TX35R - HDMI Connection Problem? JPP01 General Home Cinema Chat 4 31-10-2007 6:18 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
