11-05-2009, 2:13 PM
#1 (permalink)
| | Illustrious Member
Thanks: Gave 890, Got 1,688 | Firefox Maxing out cpu load
Firefox keeps on loading up some of my cores to 100% when I view certain sites (hotmail is one of those sites).
It has done this on two of my pc's and is starting to annoy me. Does anyone know why and how to correct this? Could it be a flash issue?
__________________ Click 4 Pics 70" 1080p SXRD Pio AX4ASi-S, SkyHD, 360Elite, 360, PS3, Wii, Bose AM15, NevoSL Watercooled Games HTPC LC17, P6T Deluxe, i7 920@4.0Ghz, DTek FuzionV2, 4870X2+EK waterblock, 64Gb SSD, 6Gb, Forte, Enermax 1250W Rev+, Zalman Reserator XT, PA120.3 - 2nd Gaming PC, 2nd HTPC, Pronto, 50PZ80 |
11-05-2009, 2:16 PM
#2 (permalink)
| | Member
Thanks: Gave 4, Got 20 | Re: Firefox Maxing out cpu load
I get this on youtube. Makes the sound pop. Does my head in!
11-05-2009, 2:20 PM
#3 (permalink)
| | Prominent Member
Thanks: Gave 419, Got 562 | Re: Firefox Maxing out cpu load
you tried opening up a few flash windows with chrome, safari, ie, opera etc?
funny you should mention it i've been getting a few crashes/cpu load locks using firefox recently - only on xp sp3 though, win7's fine |
11-05-2009, 2:21 PM
#4 (permalink)
| | Conspicuous Member
Thanks: Gave 507, Got 1,151 | Re: Firefox Maxing out cpu load
Does the same thing happen with other browsers or just FF?
__________________ [CPU: Q9450 @ 3.6Ghz|RAM: Corsair PC2-8500 (2x2GB)] [MOBO: Asus P5Q Deluxe (1406)|HDD#1: Samsung F1 750GB] [HDD#2: OCZ SSD V1 32GB|GFX: BFG 9800GTX+ OC|PSU: Corsair HX 620W] |
11-05-2009, 2:24 PM
#5 (permalink)
| | Illustrious Member
Thanks: Gave 890, Got 1,688 | Re: Firefox Maxing out cpu load
It just seems to do it on Firefox.
I tried this and it hasnt helped. Firefox 3 RC1 High CPU and Memory Use? Try This Fix. | Just Thinkin'
I am close to dumping my favourite web browser if I cant fix this.
11-05-2009, 2:27 PM
#6 (permalink)
| | Conspicuous Member
Solution is obvious to me, switch to the worlds favourite browser - Internet Explorer
Have you tried the nightly builds to see if they have the same problem?
Can you drill down and find out what those sites have in common? I'm thinking Flash ads or something.
11-05-2009, 2:30 PM
#7 (permalink)
| | Illustrious Member
Thanks: Gave 890, Got 1,688 | Re: Firefox Maxing out cpu load Quote:
Originally Posted by Singh400 Solution is obvious to me, switch to the worlds favourite browser - Internet Explorer
Can you drill down and find out what those sites have in common? I'm thinking Flash ads or something. | I hate IE with a passion.
You could be right about flash adds. Only firefox is showing up in processes in task manager. Nothing else is showing any load.
11-05-2009, 2:33 PM
#8 (permalink)
| | Conspicuous Member
Thanks: Gave 507, Got 1,151 | Re: Firefox Maxing out cpu load Quote:
Originally Posted by Razor You could be right about flash adds. Only firefox is showing up in processes in task manager. Nothing else is showing any load.  | Well uninstall the flash plugin and visit those sites and see what happens.
Theres always Chrome or Opera.
11-05-2009, 2:46 PM
#9 (permalink)
| | Illustrious Member
Just tried un-installing all flash entries and its exactly the same. My memory load has gone down from 2.3 to 1.4gb?
At least its giving my cores a good workout.
11-05-2009, 2:49 PM
#10 (permalink)
| | Conspicuous Member
Originally Posted by Razor | Can you start FF in no-addons mode? Try that.
The memory thing has been a FF problem for a while, they never did fix it. It leaks like crazy.
11-05-2009, 2:56 PM
#11 (permalink)
| | Illustrious Member
That seems to of done it. Cheers Singh.
I had add blocker and image zoom. So it has to be one of those apps.
11-05-2009, 2:58 PM
#12 (permalink)
| | Conspicuous Member
No problem mate
Now about IE....
11-05-2009, 3:06 PM
#13 (permalink)
| | Illustrious Member
Originally Posted by Singh400 No problem mate Now about IE....  | I get a shiver down my spine every time I read that word or hear it.
11-05-2009, 3:30 PM
#14 (permalink)
| | Illustrious Member
Just in case anyone else is having the same issues, the culprit seems to be Addblockplus.
11-05-2009, 4:50 PM
#15 (permalink)
| | Member
Thanks: Gave 12, Got 4 | Re: Firefox Maxing out cpu load Quote:
Originally Posted by Razor Just in case anyone else is having the same issues, the culprit seems to be Addblockplus.  | One of the best addon's available... |
