Help me choose an iron
Old 06-03-2009, 1:05 PM   #1
Liquid101's Avatar
15,138, Level: 29
Points: 15,138, Level: 29 Points: 15,138, Level: 29 Points: 15,138, Level: 29
Activity: 10.6%
Activity: 10.6% Activity: 10.6% Activity: 10.6%
Thanks: Gave 596, Got 1,488
Red face Help me choose an iron
OK, so last night the iron gave out on me mid way through my favourate handkerchief. As I am a 'new' man, I like to take my share of the household responsibilities; one of these being the designated ironing officer. Before you all laugh and ridicule, I actually quite like doing the ironing - usually with wireless headphones, bottle of beer and HD movie at point blank range.
Anyway - I need a new iron, and need advice. Where better than an AV enthusiast forum.
Is it worth getting the all singing and dancing steam generating like this, or am I better off with a mid range branded device for £40
I enjoy a nicely ironed shirt, and want to achieve the best possible result. Do these steam generating ones really make that much difference?
Any advice is welcomed.
Old 06-03-2009, 1:17 PM   #2
Conspicuous Member
Crocodile's Avatar
15,098, Level: 29
Points: 15,098, Level: 29 Points: 15,098, Level: 29 Points: 15,098, Level: 29
Activity: 15.2%
Activity: 15.2% Activity: 15.2% Activity: 15.2%
Thanks: Gave 408, Got 1,147
Re: Help me choose an iron
Any Recomendations for a steam iron
Old 06-03-2009, 1:28 PM   #3
xit2050's Avatar
9,735, Level: 23
Points: 9,735, Level: 23 Points: 9,735, Level: 23 Points: 9,735, Level: 23
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 239, Got 441
This is a good one.
Old 06-03-2009, 1:28 PM   #4
Decadence's Avatar
10,903, Level: 25
Points: 10,903, Level: 25 Points: 10,903, Level: 25 Points: 10,903, Level: 25
Activity: 4.5%
Activity: 4.5% Activity: 4.5% Activity: 4.5%
Thanks: Gave 1,288, Got 1,272
Steam generating iron all the way, you really do get what you pay for in these cases.
Old 06-03-2009, 1:58 PM   #5
Mac Man's Avatar
9,703, Level: 23
Points: 9,703, Level: 23 Points: 9,703, Level: 23 Points: 9,703, Level: 23
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 220, Got 240
Yep.... ditto.
Less filling up at the tap and you use the steam to iron your clothes, not the heat of the baseplate - so less chance of damaging the material. Ours has conked out so I'm reduced to using a normal iron. Seems to take twice as long and the results are nowhere near as good.
Old 06-03-2009, 2:10 PM   #6
3,278, Level: 13
Points: 3,278, Level: 13 Points: 3,278, Level: 13 Points: 3,278, Level: 13
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 379, Got 1,193
Steam one! However I don't have a recommendation because I'm still waiting for my second hand iron from university to die (that's 8 years!! ) before I buy a new iron.
Old 06-03-2009, 2:15 PM   #7
Liquid101's Avatar
15,138, Level: 29
Activity: 10.6%
Originally Posted by crocodile View Post
Thanks for that - didn't think to search the archive. I suppose I thought it wasn't likely to be a previously asked queston
Thanks for the replies - looks like a steam generating one is the way to go.
Old 06-03-2009, 2:17 PM   #8
3,874, Level: 14
Points: 3,874, Level: 14 Points: 3,874, Level: 14 Points: 3,874, Level: 14
Thanks: Gave 36, Got 326
A Man's Steam Iron.
You'll want one with a go faster stripe on to speed up the ironing.
You'll need one that holds at least a gallon of water so the steam won't run out half way through the job.
And when you press the steam button, it will have to make a noise like an old steam train so you know you are doing a proper job.
It will have to be made from cast iron and nothing else,remember light weight irons are for women and wimps.
There should be a beer holder on the iron as well plus a rear view mirror in case the other half comes up behind you to offer tips on doing your shirt.
Old 06-03-2009, 5:48 PM   #9
contraste's Avatar
6,660, Level: 19
Points: 6,660, Level: 19 Points: 6,660, Level: 19 Points: 6,660, Level: 19
Thanks: Gave 80, Got 111
One for the men who iron:
Stirovap 376 boiler & iron (C Thompson Machines Ltd domestic sewing machines)
Old 07-03-2009, 9:32 AM   #10
3,439, Level: 13
Points: 3,439, Level: 13 Points: 3,439, Level: 13 Points: 3,439, Level: 13
Thanks: Gave 19, Got 28
IF you can find one, look for one with an anodised aluminium soleplate. My Philips is going strong and about a decade old without a single mark on it unlike stainless steel or ceramic (actually ceramic powder in resin - the ceramic doesn't wear but the resin does)
