21-01-2009, 2:40 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 154, Got 196 | ford ka keys
hi, we got a ford ka last week but only got one key with it, the black one with the red chip in top. timpsons said they could cut us another from that and program. ive read around and some people say that doesnt work as you need the red master key. has anyone done this? thanks.
xbox360 tag M0E SYZLAK
21-01-2009, 3:39 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 196, Got 256 | Re: ford ka keys
AIUI, it IS possible to clone that key, and it will work, what won't be possible, is to program new keys using those keys...
__________________ I HAVE NOTHING INTERESTING TO SAY!!! |
21-01-2009, 4:18 PM
#3 (permalink)
| | Member
Thanks: Gave 78, Got 166 | Re: ford ka keys
The key you have is the master key, I have one like that with my Mondeo. The red plastic bit hides the transponder. I think they're blue on later models.
It's possible to program the remote central locking on a new key using the key you have. However, to program the immobiliser yourself, you'll need a third key.
Have a word with your local Ford dealer and see how much they charge. I bought a key off Ebay and my kindly Ford dealer cut it for me for nothing. |
21-01-2009, 4:25 PM
#4 (permalink)
| | Senior Member
Thanks: Gave 154, Got 196 | Re: ford ka keys
thanks. i thought the master key was red? so its possible to get a ket cut
from this key in timpsons and the immobilser would work?
21-01-2009, 4:34 PM
#5 (permalink)
| | Member
Thanks: Gave 78, Got 166 | Re: ford ka keys Quote:
Originally Posted by ROBIN50N thanks. i thought the master key was red? so its possible to get a ket cut
from this key in timpsons and the immobilser would work? | If you get a key (with remote locking) cut it will open the door manually and you can sync it with the remote central locking so that works. It won't start the car though, as you need a third key to program the immobiliser.
21-01-2009, 4:38 PM
#6 (permalink)
| | Senior Member
this is confuseing. the car only has an immobilser. so its not possible to clone them at key cutting shop?
21-01-2009, 4:42 PM
#7 (permalink)
| | Member
I don't think so.
21-01-2009, 6:36 PM
#8 (permalink)
| | Senior Member
Anyone else had this? Just want to be sure if timpsons clone my
Black key would the cloned key work with the immobiliser.
21-01-2009, 6:48 PM
#9 (permalink)
| | Senior Member
Thanks: Gave 235, Got 252 | Re: ford ka keys
The red key is the main "Master" key. If you would like another making they can "clone" the key ( around £25 from Timpson) if yuor only looking for a key to open you door then any standard "ford" key will do at around £5 each.
You will be paying more for a "transponder" key which is the chip+ its housing.
This is my advice and my opinion only.
21-01-2009, 6:54 PM
#10 (permalink)
| | Senior Member
Thanks: Gave 154, Got 196 | Re: ford ka keys Quote:
Originally Posted by Ayub The red key is the main "Master" key. If you would like another making they can "clone" the key ( around £25 from Timpson) if yuor only looking for a key to open you door then any standard "ford" key will do at around £5 each.
You will be paying more for a "transponder" key which is the chip+ its housing. | thanks,we dont have the red master key we just have one black key with red chip in corner, so they can clone a key from that and the immobilser would work?
22-01-2009, 8:35 AM
#11 (permalink)
| | Senior Member
Yes, you can make a key from the mainly black with the red mark ( where the transaponder is located).
The key will be a "clone" from yours. This will set you back £25 (£30 max) depending on the shop.
This will work with your cars ignition doors etc
or
Butcher you key remove transponder chip stick it behind your key barrell and your new key will cost a fiver ( no programming is needed , only a simply blank) . If you car is stolen you will have to explain why you disabled your cars security.
my 2p worth.
22-01-2009, 8:37 AM
#12 (permalink)
| | Senior Member
Thanks: Gave 235, Got 252 | Re: ford ka keys Quote:
Originally Posted by ROBIN50N thanks,we dont have the red master key we just have one black key with red chip in corner, so they can clone a key from that and the immobilser would work? | Yes, most timpsons ( the one in bradford did a year or so back) if not i know a shop here which will code anything up for a price.
22-01-2009, 10:00 AM
#13 (permalink)
| | Senior Member
thanks for that mate.
