How to show thumbnails?
Old 05-12-2008, 12:09 PM   #1
Joe Pineapples's Avatar
15,971, Level: 30
Points: 15,971, Level: 30 Points: 15,971, Level: 30 Points: 15,971, Level: 30
Activity: 18.6%
Activity: 18.6% Activity: 18.6% Activity: 18.6%
Thanks: Gave 218, Got 204
I use photobucket, and want to show thumbnails of images linked to some on there, but no idea how.
can anyone help?
cheers
joe
Old 05-12-2008, 12:13 PM   #2
Illustrious Member
Singh400's Avatar
32,635, Level: 44
Points: 32,635, Level: 44 Points: 32,635, Level: 44 Points: 32,635, Level: 44
Activity: 19.9%
Activity: 19.9% Activity: 19.9% Activity: 19.9%
Thanks: Gave 901, Got 2,136
Re: How to show thumbnails?
Typically, you'll have 2 URLs. One is for the main image, and one is for thumbnail image. Use the following code:
PHP Code:
[url=INSERT.MAIN.IMAGE.URL.HERE][img]INSERT.THUMBNAIL.URL.HERE[/img][/url
Old 05-12-2008, 12:29 PM   #3
15,971, Level: 30
Activity: 18.6%
thanks Singh- i'll give that a go
Old 05-12-2008, 12:32 PM   #4
Iccz's Avatar
29,936, Level: 42
Points: 29,936, Level: 42 Points: 29,936, Level: 42 Points: 29,936, Level: 42
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 3,753, Got 4,288
Or just resize the main image to a smallersize - not ideal if you have a page of 20 images or so...
if there's lots use what singh said, if it's just 1 or 2 pics then use the following:
Code:
<img src="image.jpg" width="100" height="100">
obviously size to suit.
Old 05-12-2008, 12:36 PM   #5
Illustrious Member
Singh400's Avatar
32,635, Level: 44
Activity: 19.9%
Might be worth mentioning that most image sites (eg ImageShack) actually produce the code you need. All you need to do is copy and paste
Old 05-12-2008, 12:40 PM   #6
Iccz's Avatar
29,936, Level: 42
Activity: 20.9%
looking at photobucket the thumbnails just have a prefix on images, so:
becomes:
Old 05-12-2008, 12:43 PM   #7
Illustrious Member
Singh400's Avatar
32,635, Level: 44
Activity: 19.9%
Yep yep. Imageshack uses image.jpg and image.th.jpg.
Old 05-12-2008, 12:55 PM   #8
15,971, Level: 30
Activity: 18.6%
Ok, i have the thumbnails working (thanks),. but now i want to arrange them in a row, rather than the current column i'm getting. Any ideas?
Old 05-12-2008, 12:58 PM   #9
Illustrious Member
Singh400's Avatar
32,635, Level: 44
Activity: 19.9%
Instead of hittin [RETURN] or [ENTER], use space bar.
Old 05-12-2008, 12:59 PM   #10
15,971, Level: 30
Activity: 18.6%
DOH! thanks
