Fleece Jackets
Old 18-11-2008, 2:19 PM   #1
Iccz's Avatar
29,842, Level: 42
Points: 29,842, Level: 42 Points: 29,842, Level: 42 Points: 29,842, Level: 42
Activity: 33.7%
Activity: 33.7% Activity: 33.7% Activity: 33.7%
Thanks: Gave 3,753, Got 4,287
Fleece Jackets
Where is a good place to buy a good warm fleece that's not really "bulky" and not overly expensive.
Looking at getting one for my Dad for christmas as he's starting to feel the cold a bit more these days and being unable to drive due to eyesight often walks to the shop in the village and sometimes walks to the next town.
looking for something up to £100, but obviously £30-60 would be an ideal price range.
Not really looked at this kind of item before so I don't know what to look for or what brands are good.
I was thinking of going to The Outdoor Shop on the way home from work and having a look there.
anyone have any other shop suggestions or online retailers?
Thanks!
Old 18-11-2008, 2:30 PM   #2
mikeycubed's Avatar
4,720, Level: 16
Points: 4,720, Level: 16 Points: 4,720, Level: 16 Points: 4,720, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 676, Got 385
Re: Fleece Jackets
How about a Bench fleece from here - M & M Direct or a Berghaus
I've used them loads of times and never had a problem.
HTH,
Mike
Iccz (18-11-2008)
Old 18-11-2008, 2:33 PM   #3
Iccz's Avatar
29,842, Level: 42
Activity: 33.7%
Re: Fleece Jackets
HTH,
Mike
Ahh yeah Berghaus, I think there is or was one of their stores in the Milton Keynes Centre.
The one with the hood is probably best, seeing as he doesnt have much hair to keep his head warm
Old 18-11-2008, 2:34 PM   #4
Illustrious Member
Sonic67's Avatar
16,893, Level: 31
Points: 16,893, Level: 31 Points: 16,893, Level: 31 Points: 16,893, Level: 31
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 1,344, Got 1,774
Re: Fleece Jackets
Fleeces at Silvermans:
http://www.silvermans.co.uk/ProductD...8/Default.aspx
Iccz (18-11-2008)
Old 18-11-2008, 2:43 PM   #5
Conspicuous Member
nheather's Avatar
17,661, Level: 32
Points: 17,661, Level: 32 Points: 17,661, Level: 32 Points: 17,661, Level: 32
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 595, Got 1,168
Re: Fleece Jackets
Not entirely sure what you are looking for in a fleece.
My understanding is similar to that of the last poster. I have a Berghaus, but for winter this is really part of a layered clothing.
Base (your shirt), Mid (fleece), and then shell (nylon\gortex jacket).
In fact some of these fleeces and shells are interactive in that they will zip together so that the fleece forms a lining.
But where I coming from is that I would not consider one of these fleeces to be a jacket for winter use. It would be similar to walking down to the shops in a pullover. I use mine on its own on dry spring\summer\autumn nights instead of a jacket to keep the chill out.
I suspect you want a fleece lined jacket (a waterproof\windproof outer with a fleece inner).
In which case I'd look at the following
M&S
BHS
Peter Storm (Millets)
Regatta
You will probable find the likes of Berghaus, The North Face, Sprayway out of your budget.
Another good store is Go Outdoors but there are not that many in the UK so your nearest may be too far away.
Cheers,
Nigel
Iccz (18-11-2008)
Old 18-11-2008, 2:48 PM   #6
Iccz's Avatar
29,842, Level: 42
Activity: 33.7%
Re: Fleece Jackets
Cheers Nigel, that's a top post there, I didn't really take into consideration about the wet conditions which with a fleece... yeah I see why now, i'll have a look at the price of the 2 part ones when I go into town, I assume there are reversable ones also... he has a couple of waterproof jackets, so im sure he can just put them over a fleece if he uses it like a jumper.
Old 18-11-2008, 2:58 PM   #7
Orson's Avatar
5,260, Level: 17
Points: 5,260, Level: 17 Points: 5,260, Level: 17 Points: 5,260, Level: 17
Thanks: Gave 265, Got 257
Re: Fleece Jackets
If it's any use, I was in a TK-Maxx last week, and they had lots of choice of fleece jackets, reversible ones too, and some 2-part ones as described by Nigel above (first time I'd come across them too). Prices were around the £30 to £50, and were mainly Regatta.
Iccz (18-11-2008)
Old 18-11-2008, 3:00 PM   #8
Iccz's Avatar
29,842, Level: 42
Activity: 33.7%
Re: Fleece Jackets
Maybe I can get one with a knife attached to it, though I think they stopped selling them
Old 18-11-2008, 3:03 PM   #9
mikeycubed's Avatar
4,720, Level: 16
Activity: 1.9%
Re: Fleece Jackets
Here's a Regatta 3 in 1 Jacket - M & M Direct Seems like a good price and no I don't work for them
Old 18-11-2008, 6:40 PM   #10
15,816, Level: 30
Points: 15,816, Level: 30 Points: 15,816, Level: 30 Points: 15,816, Level: 30
Thanks: Gave 583, Got 289
Re: Fleece Jackets
Craghoppers Corey fleece....Corey Microfleece - Craghoppers
£9.99+vat at Costco. If it's very cold i just put on a light trespass base layer underneath.
Iccz (18-11-2008)
Old 18-11-2008, 6:46 PM   #11
5,242, Level: 17
Points: 5,242, Level: 17 Points: 5,242, Level: 17 Points: 5,242, Level: 17
Thanks: Gave 453, Got 238
Re: Fleece Jackets
Mens Fleeces, Midlayers and Windproof Mens Fleece Jackets from GO Outdoors UK
If your budget would stretch to it i would recommend something with a windstopper membrane.
Can personally recommend Rab double pile berber fleece.
Iccz (18-11-2008)
Old 18-11-2008, 6:59 PM   #12
2,983, Level: 12
Points: 2,983, Level: 12 Points: 2,983, Level: 12 Points: 2,983, Level: 12
Thanks: Gave 43, Got 58
Re: Fleece Jackets
tk max are quite good ,reggatta not bad,i think there is a tkmax in mk central
Old 18-11-2008, 6:59 PM   #13
Iccz's Avatar
29,842, Level: 42
Activity: 33.7%
Re: Fleece Jackets
I really like the look of this one
Berghaus Polarplus Interactive Mens Jacket - £63.00 - from GO Outdoors.co.uk
Is there any reason to go for a different one around the same price or cheaper?
Reading about it, sounds just ideal to me.
Yeah it's over by Bletchley, I might go have a look in there this weekend if i'm free
Old 19-11-2008, 12:35 AM   #14
huwg's Avatar
6,418, Level: 19
Points: 6,418, Level: 19 Points: 6,418, Level: 19 Points: 6,418, Level: 19
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 134, Got 126
Re: Fleece Jackets
I second the lined wind-stopper fleeces, SprayWay do some nice ones.
I also agree it may be worth considering a fleece with an 'IA' zip so it can be zipped inside a water/wind proof outer at a later date. This is not essential as the outer can simply be worn on top of the fleece.
Iccz (19-11-2008)
Old 19-11-2008, 12:40 AM   #15
Iccz's Avatar
29,842, Level: 42
Activity: 33.7%
Re: Fleece Jackets
Aye that one does look the dogs, I think i'll go look at the cheaper fleeces in town and try them on see how comfortable and warm they feel, then see wether I can justify a big spend on one
