Go Back   AVForums.com > Lifestyle Topics > General Chat
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
LCD TV sales tumble, Samsung still on top The News Bot Home Cinema and Tech News 0 15-06-2007 6:20 AM
Tabletop Tumble Dryers Geordie Jester Home Appliances (Cooking/Cooling/Cleaning) 1 30-12-2006 12:41 PM
ipod price tumble... kokoshka Portable Music (MP3, iPod etc.) 1 24-05-2006 10:10 PM
Residual Current Device for hair drier near handbasin brains Home Automation, Lighting, Security, Heating and Cooling 3 15-03-2005 12:47 PM
Old 12-10-2008, 10:56 AM   #1 (permalink)
Thanks: Gave 108, Got 24
What tumble drier?
Should i get a condensed or vented one, which one is better?
i want to spend around 200-250.
Mayhs is offline   Reply With Quote
Old 12-10-2008, 11:56 AM   #2 (permalink)
GasDad's Avatar
Thanks: Gave 184, Got 234
Re: What tumble drier?
Vented - less to go wrong.
And Meile is the only choice.
Sky HD, Yamaha 757SE, Pioneer 436XDE, Quad Lites
GasDad is offline   Reply With Quote
Old 12-10-2008, 12:19 PM   #3 (permalink)
SyStemDeMoN's Avatar
Thanks: Gave 121, Got 96
if you've got somewhere to hang a pipe out of a window then vented, if not the condensed.
i hate the condensed ones to be fair, they usually make your clothes really creased.
i have a rather cheap indesit(indishit) tumble dryer, vented, and it is really good to my surprise. most clothes that come out dont need ironing. in fact its so good at it, i dont bother hanging clothes out even when the weather is fit for it!!
im not sure ur gonna get a melie for your budget tho
Panasonic TH-50PZ70, Toshiba EP30, Sky +, Denon ADV-1000, PS3 PSN systemdemon, 1 wife, 2 kids(boys), 1 alsation(german shepard), 1 weimaraner and 1 cat(Mr. Bigglesworth)
"It's a pity you Autobots DIE so easily, or I might have a sense of satisfaction!" 360SelfRepaired!
SyStemDeMoN is offline   Reply With Quote
Old 12-10-2008, 12:34 PM   #4 (permalink)
danmc_82's Avatar
Thanks: Gave 338, Got 178
Like in post 2 Meile is the best but consider the electricity bill
Kit List: SkyHD, PS3 160GB, Yamaha RX-V1900, Monitor Audio RS6, RSLCR, RSFX, XLS 300PR, Sony 40KDLW2000 LCD.
PSN: danmc_82
danmc_82 is offline   Reply With Quote
Old 12-10-2008, 12:48 PM   #5 (permalink)
Dony's Avatar
Thanks: Gave 435, Got 474
We have never owned a clothes line All drying gets done in the drier overnight to cut down on the costs.
Dony is offline   Reply With Quote
Old 12-10-2008, 2:13 PM   #6 (permalink)
thanks for the help, is it a general characteristic of condensed ones to crease clothes or do the rubbish ones only do it? I dont think my parents want to put a hole through the wall, which is what you have to do with a vented one right?
Old 12-10-2008, 2:52 PM   #7 (permalink)
danmc_82's Avatar
I took the plug off ours, have seen a drop in bills because of it.
It does seem like hard work taking it out, handing it, then bringing back in but after a while its just part of everyday life.
If its wet outside we use a clothes horse
PSN: danmc_82
Old 12-10-2008, 3:01 PM   #8 (permalink)
Newton's Ring's Avatar
Thanks: Gave 126, Got 53
We've got a condensing type - you just empty the water tank when full. It's pretty easy really.
It's currently sat in my shed at the bottom of the garden. I refuse to put any of my clothes in it because they come out fit for a 9 year old after an hour or so in the thing.
Now it's either the whirlygig or the radiators - the house looks untidy a good proportion of the time but I'd rather that than wreck my clothes. I have a hard enough time getting in my clothes as I get older anyway, without help from the incredible shrinking machine.
Newton's Ring is offline   Reply With Quote
Old 12-10-2008, 3:06 PM   #9 (permalink)
GasDad's Avatar
Yup you need to make a hole in the wall.
This has pros and cons.
Pros - you get to hire an enourmous drill and diamond core bit and get to pose like it's the BFG from Doom.
Cons - you have to sit still for a few hours actually drilling the hole - you'll be amazed how slow such a big drill can be.
Assuming bricks walls (rather than random stone), it doesn't make much mess, is easy to do and will take less than a morning.
Old 12-10-2008, 3:58 PM   #10 (permalink)
Thanks: Gave 147, Got 604
We've had a Bosch condenser for 6 years.
It doesn't crease clothes.
It doesn't shrink clothes.
Crocodile is offline   Reply With Quote
Old 12-10-2008, 4:03 PM   #11 (permalink)
GasDad's Avatar
But does it dry clothes ???
Old 12-10-2008, 4:06 PM   #12 (permalink)
Thanks: Gave 133, Got 65
I've also got a Bosch as i find most Bosch products are good quality and reliable from my experience anyway
Throttle is offline   Reply With Quote
Old 12-10-2008, 4:22 PM   #13 (permalink)
i think u can get a little box type thingy that u can put your pipe from your vented dryer into and it stops all the condensation from the dryer. this means that u dont have to knock a hole in the wall, but simply use the box instead.
however this does warm up the room its in, so leave a window open in there.
Old 12-10-2008, 4:27 PM   #14 (permalink)
Thanks: Gave 314, Got 185
Vented dries are cheaper to run than condensing although we keep our condensing drier in a bedroom and it warms upstairs quite nicely.
ufitsy is offline   Reply With Quote
Old 14-10-2008, 9:13 AM   #15 (permalink)
Autopilot's Avatar
Thanks: Gave 247, Got 443
Just noticed this thread after buying a new drier ourselves and running it for a couple of days. I'm surprised no one has mentioned Sensor drying - it stops when your cloths are dry. Genius. Because people always put it on for a bit longer than needed, it can save a lot of money over the year and less hassle. Set and forget.
We got condensed because they are much more convenient. There is not much to go wrong TBH, don't let that put you off because all they do is push the air through a metal box/radiator type thing that cools the air so the moisture drops out (i.e condenses) rather that just pumping it out and pulling new dry air in. Its a very simple process. Every month or so it gets pulled out and run under a tap. It can take a bit longer than vented , but thats ok if you have sensor drying, and not much anyway (our is faster than my mothers one and one we have at work, both vented) - how fast your washing machine spins makes more of a difference. Some can be set up as both vented and condenser now too. We have a decent Hoover model and i guess you get what you pay for. No problems with ours creasing and shrinking cloths, but we only put stuff in that can be tumble dried and use the right setting
The other thing is reverse drying - drum goes both ways to stop stuff getting rolled up in a ball and taking ages or coming out a bit damp in the middle. And get the biggest drum size you can as it will dry faster. Don't, whatever you do, buy a washer-drier.
Cheers, Auto.
Lounge: Panasonic P37X10, Topfield 5810 PVR, Philips BDP3000, Squeezebox 3, Harmony One, Cambridge Audio 640A, Mission 701's Kitchen: Squeezebox Touch, Trends TA-10.1, Kef Cresta 1's. Bedroom: Squeezebox Boom Bathroom: Squeezebox Radio Car: iPod Classic 80Gb Portable: iPhone 3GS 32Gb
Autopilot is offline   Reply With Quote
drier, tumble
